I've been trying to reset my annual service on the sled as well as the desmo (although the light is not yet popped up, but i've done the job so).
I am using https://www.lonelec.com/product/obd2-wi ... ader-v1-5/ and am able to connect to it via Melcodiag. I am not able to pull a report to get a license with "M3C" ticked, only with "Any bike" selected, sent that and received the license yesterday. Tried resetting but it does not work.
I can connect and read the VIN and it is correct but it does not seem to provide proper "ECU Type" or "Hardware version" with "Any bike" ticked
I had one session where it connected with M3C and read "CAN ERROR" ECU type, VIN and so on.
Any idea of what could be wrong?
And sorry JP! I sent an email before reading that this should be way of communications.
2021 Desert Sled issues
Re: 2021 Desert Sled issues
can you post the report with each of selected mode ?
Any bike:
"File generated On 2025-06-12 22:57:31"
"Auto Detect Bike = Ducati Scrambler Desert Sled 2021 EU5"
"User Bike = 2021"
"Hardw = """
"Softw = 22000000"
" vin DATA
vin 7F1A11CCCCCCCC
vin 7F1A22
vin 31A8F03145A8F035A444D354B303041414D42303030383033
020_004000100000072C
02A_000180000000073C
174_0080005B496B0C53
178_0480000037690C74
17C_0080010019800C0E
024_0000000000060398
188_7FFF7FA780C34129
022_000000000003F1BC
18C_800380020000025F
023_000000547F430118
080_2BC2BC1F00000388
100_C802000FFF0012BA
"Vin = ZDM5K00AAMB000803"
"C6F341C2"
ZDM5K00AAMB000803
ZDM5K00AAMB000803
And M3C:
"File generated On 2025-06-12 22:56:32"
"User Bike = 2021"
" vin:NO DATA>
020_0040001000000ED9
02A_0001800000000EC9
080_2BC2BC1F00000B60
100_C802000FFF001A52
188_80037FA380C3471F
022_000000000003F7F2
18C_800380020000088D
023_000000547F47077B
174_FE7F005A306B0551
178_0C80082D226905B0
17C_00800100138005F4
300_3B8000080B02CF43
230_0000100000000F5F
220_0000000000000FB1
"C6F341C2"
ZDM5K00AAMB000803
"User Bike = 2021"
"Hardw = """
"Softw = 22000000"
" vin DATA
vin 7F1A11CCCCCCCC
vin 7F1A22
"C6F341C2"
ZDM5K00AAMB000803
ZDM5K00AAMB000803
And M3C:
"User Bike = 2021"
" vin:NO DATA>
"C6F341C2"
ZDM5K00AAMB000803
i'mnot sure your bike has a continental ecu M3C , can you confirm it ?
else for the light reset you may need to wait the light comes up
So from your side it is looking ok?
The yearly service is showing up, but I can not remove it.
Image below shows picture of the ECU, not sure if that helps?
https://share.icloud.com/photos/0d6r6K_ ... zJBgS5VGBQ
yes all looks ok
it's not a m3c but i don't know the made
Glad to know I’ve done it correct at least! So that means I can not reset the service light, or should ”any bike” work?
i think any bike is the right option.
we can try different settings / resets by changing the bike model manually
i'm sending you some instructions
Awesome, thanks! I’ll try it as soon as I can
I’ve tried all the bike models but no luck. And it is “service intervaI” I should reset, right?
can see the OBD reader sending/receiving but nothing. Is there any indication from Melco when it should be a success?
Could the issue be that I did not tick “oil service active” when I requested the license?
