Hello There,
The bike seems to connect, melcodiag reads VIN correcty. While going through the registration process, I get this error message:
"Be sure you are using the right software and the rights cables for connecting to your bike , data are incomplete!
back, clic here"
This is from the "registration" screen:
300_000000420000A656
80_22D22DC00500059F
Global_ vin 145A8F035A444D4D41434657304842303234323438 vin DATA vin DATA vin DATA12 PIDS active founds 024_0000000000000BC5 080_22D22DC005000B39 018_0002A00042004EB2 019_9609600000000E75 020_0040551000000C4D 100_C812004000000B64 174_19800000669504A1 178_E47F0724548304C2 17C_0000000029960405 188_7FF77E7F80734DC5 022_000000000003FD20 023_000000547F6B0DAB
ZDMMACFW0HB024248 OIL0_DES0
and this is the report from melcodiag:
"File generated On 7/4/2025 2:54:00 PM"
"Software version 2.0.4.5"
"Auto Detect Bike = Monster 1200"
"User Bike = Monster 1200 S 2017"
" vin 145A8F035A444D4D41434657304842303234323438
"Vin = ZDMMACFW0HB024248"
"028F3883"
ZDMMACFW0HB024248
Please help.
*** Update 7/5/25 ***
I checked the forum, noticed user tarmac31 had a similar issue and still received the license file after a few days .. so perhaps there is still hope? Thanks
Need registration help - Melcodiag
Re: Need registration help - Melcodiag
the reason of this message is that mecodiag cannot grab any data
CAN Bike = "
to the server is not processing your request
if you want to bypass this check, you have to replace the first empty line in the submission form , which should be the bike , with no bike data
CAN Bike = "
Thank you Jpl250, it bypassed the check and sent a request for license. I'm on standby now ..
yes it bypassed , but you put in bike field no ecu data , i wasn't expecting it here.
in bike model , you shall put the bike model and year i cannot guess it only with the prefilled data
So you want 1) "Monster 1200 S 2017 " in the field "bike/year?' inside the box "debug info for report and registration" 2) hit the "Get license" blue button and then in the following form, in the "bike model" field right above the email address, you want "no bike data" to bypass the check .. correct?
no no
the field bike in the app is only used for the debug report not for registrering app
all you have to do for register is to establish the connection with the bike , when all data are populated , you press get lic button,
once the register page is shown , you enter you bike name( not no bike data) / year and email ,
the last text bloc is already prefilled , it's in this bloc you replace 1st line with no bike data
Thanks, I just followed your procedure and it looks like the request for license was sent.
yes perfedct this time
"File generated On 24/09/2025 15:55:12"
"Auto Detect Bike = MTS1200 ENDURO"
"User Bike = mts 1200 enduro 2016"
"Ecu = No ecu data"
"Softw = 10SW041702U"
" vin 145A8F035A444D4141303341414742303131353734
vin 7F1A1255555555
vin 7F1A1255555555
vin 0C5A953130535730343137303255
15 PIDS active founds
100_C712038035000DC8
120_48E8793CDC482FFA
022_000000000003F386
020_0000B9000000876E
023_000000FC7F570358
174_14800000956A0BB9
178_0080030262800B66
17C_00000000C4950B7F
188_7FEF8007809B4393
230_12801000000C0E96
240_0100600442000102
018_0002A000A40046CF
019_960960000000069D
024_000000000000
"Vin = ZDMAA03AAGB011574"
"FDC721DF"
ZDMAA03AAGB011574
cosa non va? puoi controllare per favore?
"Ecu = No ecu data"
vin 7F1A1255555555
vin 7F1A1255555555
024_000000000000
"FDC721DF"
ZDMAA03AAGB011574
all looks good
you can register it , but reset won't work cause it's a 10sw software
