Integer is not valid
namronnorman
I am struggling to connect to my 2023 Ducati Scrambler (not the next-gen model). I've used the program before to reset my service, but I am currently getting the issue below. I get this error when I select MC3, when I choose anybike it will pull up some of my info, but will direct me to tick MC3.
- Connection Error.png (128.76 KiB) Viewed 2524 times
Re: Integer is not valid
oh i see ,
i'm working on a new version which i hope fix this.
it's not yet finish , but the connection issue shoulb be better.
if you want to try it i can link you to the beta
namronnorman
Yes please! The only thing different from my setup from before is using a new laptop. I do not have another at my disposal to try.
let me know if it's better with this one
v2.0.5.0 is online
v2.0.5.0 is online
namronnorman
No luck
"Index was outside the bounds of the array"
Any other ideas? I've tried the other USB ports and all the bauds. Made sure my drivers were all good. I'm stumped.
- MelcoDiag3 attempt.png (240.09 KiB) Viewed 2494 times
not really ,
i would need to do a remote session.
it looks like the ignition is off instead of on
debug report may help too
Robertbenson30
Hello, any luck with the solution? I'm have the exact same issue with my 2018 Monster 797. Tried the link above for the beta. No luck. I'm using the 1.4 interface. Able to connect with MC3 software but there's no option to clear desmo.
we still not do a remote session for investigating
Robertbenson30
I can do the remote if you'd like?
great so let's plan a schedule and get connected with rustdesk when ever you can
