Issue connecting to Multistrada 1200s 2015
hORn
Post by hORn »
Good day,
Recently tried to use Melcodiag of last version to connect to my bike.
I have Vgate vLinker MC+ adapter which supports almost any ELM327/329 software. Melcodiag reports adapter as ELM327 v2.2.
The issue is either it connects and gets only VIN and model name, when using "Any bike" option, but no HW/SW data and while register attempt is says data is invalid. Or just connects and no data at all, once "M3C.." option is used. Also tried all different COM port speed options.
Is the problem in my adapter or am I simply doing something wrong?
PS: the same adapter, but other software like CarDiag, reads all standard OBD data well.
Thank you!
Re: Issue connecting to Multistrada 1200s 2015
can you post the report here ?
hORn
Post by hORn »
Is it the one with data when trying to register? I've tried with button "Write report", but despite is says report has been written, I didn't find a file (and clipboard is empty too).
Code: Select all
300_3F98000038B449D9
Global_ vin 145A8F035A444D4141303041414642303031353334 vin 7F1A12 vin 7F1A12 vin 7F1A1217 PIDS active founds 178_0080032370770163  018_0002A00082004B7B  019_9609600000000B1C  17C_000000000A940148  022_000000000003FA73  023_000000FC807F0A8C  188_80037B237F8B4AA0  020_0000950000004FB0  024_000000000000047E  080_192000003020043D  100_C7120360350004D6  174_118000007E6A0268  230_01801000001C00DA  607_01FE0A0155555555  587_41FE0A00AAAAAAAA  150_0000007B0000660D  210_00000031FF00D640
ZDMAA00AAFB001534 OIL0_DES0
no this is not right
you posted a part of the registration link
i need the content of the debug report .
( button create report ) check for MelcoDiag.exe.debug.txt
hORn
Post by hORn »
Ok, I've got it finally.
PS: Once MelcoDiag is put into "Program Files (x86)" folder, it can't write files inside, likely due to missing permissions.
Code: Select all
"File generated On 03/09/2025 21:51:32"
"Software version 2.0.4.6"
"ELM version : ELM327 v2.2"
"User Bike = mts1200-any"
" vin 145A8F035A444D4141303041414642303031353334
 vin 7F1A12
 vin 7F1A12
 vin 7F1A12
20 PIDS active founds
174_248000006D6A08CC
178_118002207D770827
17C_0000000039940819
024_0000000000000D8B
080_1930000030200DDC
100_C712036033000D26
020_0000950000004645
022_000000000003F1BC
023_000000FC806B01DA
188_7FE77B2B7F8B41DB
240_0078600442000C02
018_0002A00082004393
019_96096000000003F4
130_0000050003E60600
120_4A44771D14041A14
620_38B440001A010000
150_0000007800006F42
210_00000034FF010FD2
230_01801000001C092F
"Vin = ZDMAA00AAFB001534"
"A2E75034"
CAN ERROR
CAN ERROR
CAN ERROR
ZDMAA00AAFB001534
hORn
Post by hORn »
Any chance to understand what could be wrong?
yes you use an old melcodiag version , i think the last one shall works better
except this , it seems not so bad
hORn
Post by hORn »
Thank you.
With the new version it went slightly better - I was able to get software version and get the license. However, most of the data is still meaningless: oil service is not recognised (but it is active), rpms shows >20k with engine off and, engine temperature like -54 degree, traction control level is jumping all values randomly, mileage is way wrong etc. When I scan for ECUs in DTC section, it showed me 6 different lines.
Idk if it something special with my bike or with (likely) my adapter being different version compared to the mostly used here.
Code: Select all
"File generated On 29/09/2025 20:49:57"
"User Bike = g"
"Softw = 10SW037916U"
 vin 7F1A1255555555
 vin 7F1A1255555555
024_0000000022120D94
080_18D0000030200D59
100_C712036035000D23
174_27800000976A0B8B
178_088008251F770B15
17C_00000000FF930B62
022_000000000003F5C8
023_000000FC804F05F6
188_80037AFF7FC34597
240_0078600442000602
020_00009500000049FE
018_0002A0008200748A
019_96096000000004A7
300_3A9800003914031F
130_0000050003E60000
120_4A457D0948001463
*Ecu found on : 7DF ,7E8*Ecu found on : 7E0 ,7E8*Ecu found on : 7E1 ,7E9*Ecu found on : 7E6 ,7EE*Ecu found on : 7E7 ,7EF"
"DTC =  0558010504E05555 0558010504E05555 037F181100000000 037F181100000000037F181100000000 037F181100000000037F181100000000037F181100000000 100E5804513220514120517020517220000000000000 037F1811 037F1811037F1833 037F1811037F1833037F1833"
"A2E75034"
ZDMAA00AAFB001534
ZDMAA00AAFB001534
0120
NO DATA
0120
NO DATA
no DTC is ok , it just say you have 5 errors on 2 different ecus
10SW software is not allowing to reset yet
hORn
Post by hORn »
jpl250rs wrote: Mon Sep 29, 2025 7:18 pm no DTC is ok , it just say you have 5 errors on 2 different ecus
Yeah, service reset i know unfortunately... But is it expected to have some other meaningful data displayed? Coz besides dtc errors it seems nothing is really correct. It also shows me like having 5 ECUs when i scan for these. Is there confirmed compatibility with elm 2.2 version? I‘ve read it is not fully backwards compatible with 1.5ish, due to different hardware design.
