for all who are looking for elm.
I read the whole forum and a lot of information on other threads, I still don't understand which elm I should buy on Amazon. I already bought one and it turned out to be non-working, if someone tells me which one I should buy, I'll be grateful. ducati multistrada 2014
Re: for all who are looking for elm.
check odbauto , lonelec , bmdiag for the right cables
I bought this one from Lonelec https://www.lonelec.com/product/obd2-wi ... ader-v1-5/
This works for me on three different bikes. There you can also buy the right cable.
In MelcoDiag you have to change the baudrate to 115200.
Regards Alex
Regards Alex
as kalex1711 told you, the right choice should be scan II BT ELM from Lonelec, I also tried lots of elm : 1.4 1.5 USB Serial , WIFi (I know melcodiag wifi is not supported), but the SCAN II work on all my bikes /(4 monsters ), so I think the best buy. I'm not saiyng others do not work , but ha ve to try too much (with drivers, com ports and baud rate) while with BT SCAN II you can work fast without config problems.
