Comfirmed successfull RESETs
Re: Comfirmed successfull RESETs
MONSTER 821 2015 : Desmo service: ok - oil service : ok - DTC errors : NO
Ok for Ducati Scrambler 800 2022 eu5 m4c reset oil and reset desmo service, tnx!
2021 Panigale v2 annual service reset.
Monster 1100s 2009
Multistrada 1200s touring 2011 : Desmo Reset ok
2023 Multistrada V2S: Annual reset OK
2020 Ducati Scrambler Icon Dark - Annual Service Reset and PIN reset. The Annual service reset didnt work as expected, I clicked all 3 buttons that were available: Service Interval, Annual Service 0, and Annual Service 1. Im not sure exactly what caused it to work, but I did "change service date" then I hit annual service 1 and 0. When I looked over at the motorcycle I was able to edit the service date on the dash and that fixed my issue. Maybe you only need to change the service date? Not sure.
how did you change the date and what date did you put ?
I was able to change the date just as I would to change the clock on the dash. I could use the up and down switches next to the clutch to cycle through the days months and years.
Confirmed successfull RESETs
Oil service and annual service reset worked fine.
Multistrada 1260s 2018
Thank you so much!
Thank you so much!
