Pressed Annual Reset 0, then Annual Reset 1 and second time Annual Service was out, background changed from white to dark but that is easy to set back again. OBDMONSTER OBD II ELM327 V1.5 USB purchased from Amazon.
2024 Ducati Multistrada V2 S
Thanks!
Kev
Comfirmed successfull RESETs
tasmania76
Re: Comfirmed successfull RESETs
supersport 939 2018
Sucessfully reset a 1st oil service (1000km) light on a Panigale V2 2024 (Black on black)
Used a Bluetooth OBDlink LX, 3 in 1 Amazon OBD2 adapter (It has 3, 4 and 6 ports adapters).
I had to use first the OBDWiz app to start the connection with the OBDLink LX then opened melcodiag and used the COM4 to connect.
Connection seemed slow as I pressed the reset oil button and took aprox 90 secs to do the reset, so I would not recomend it for anything but the service interval reset. Whole process took me about 5 mins and then I got a low battery warning on the dash, so also seems to drain the battery pretty quick.
- Multistrada 1260s MY2018 Oil service, annual service
