Pressed Annual Reset 0, then Annual Reset 1 and second time Annual Service was out, background changed from white to dark but that is easy to set back again. OBDMONSTER OBD II ELM327 V1.5 USB purchased from Amazon.
2024 Ducati Multistrada V2 S
Thanks!
Kev
Comfirmed successfull RESETs
tasmania76
Re: Comfirmed successfull RESETs
supersport 939 2018
Sucessfully reset a 1st oil service (1000km) light on a Panigale V2 2024 (Black on black)
Used a Bluetooth OBDlink LX, 3 in 1 Amazon OBD2 adapter (It has 3, 4 and 6 ports adapters).
I had to use first the OBDWiz app to start the connection with the OBDLink LX then opened melcodiag and used the COM4 to connect.
Connection seemed slow as I pressed the reset oil button and took aprox 90 secs to do the reset, so I would not recomend it for anything but the service interval reset. Whole process took me about 5 mins and then I got a low battery warning on the dash, so also seems to drain the battery pretty quick.
- Multistrada 1260s MY2018 Oil service, annual service
Supersport 950s MY 2024
software version 2.0.4.8
ELM327 version 1.5
Annual service reset:OK
Interval sevice:OK
ELM327 version 1.5
Interval sevice:OK
Geoffhogarth
Melcodiag
2016 M821 Monster
ECU Continental Easy - U1
10500 miles service
OIl service reset successfully, no indication only 1 beep on the computer
2016 M821 Monster
10500 miles service
Multistrada 1260s MY18
Annual Reset done
Melcodiag
"ELM version : ELM327 v1.3a"
Importand to contact jpl250rs upfront: "If your bike is not a 2010 to 2012 made ,please contact jpl250rs with your VIN and model bike"
Annual Reset done
Melcodiag
Ducati Monster 821 (2019)
Annual Reset success
MelcoDiag
Software version 2.0.4.8
ELM version : ELM327 v1.5
MelcoDiag
Can I ask what ecu you have and the OS of the laptop - wondering if there's some I update I should install on the laptop - it does connect ok and I tested the side stand test which seemed to work but as I say the buttons don't seem to work - looking to do a reset on the TPS as I seem to have an issue with an erratic throttle
2016 scrambler with rexxer upmap (catless/filter tune, 02 delete).
successful desmo service reset and maintained rexxer upmap. learned that rexxer is a flash and resetting service light does not affect it.
