Monster 796, ABS, 2011 Reads but not resetting
Ciganek1
Post by Ciganek1 »
Ciganek1
Re: Monster 796, ABS, 2011 Reads but not resetting
Post by Ciganek1 »
I still can't reset the oil service or desmo reset. Melcodiag properly recognizes the ecu and connects to the ecu, I click the oil service reset button or the desmo reset button but nothing happens. The cable is ELM327 v1.5. Please
help
Can you post the report ?
Ciganek1
Post by Ciganek1 »
"File generated On 30.3.2026. 17:42:17"
"User Bike = M796 ABS 2011"
"Ecu = 5WY8691-AA"
"Hardw = QD0A3010"
"Softw = A3IU1NEI"
" vin:100E5A8C3030363021313134303234202220AAAAAAAAAAAA
10 PIDS active founds
100_0000000000400001
211_31840030D2000054
080_0000000000000000
081_01000000C9000000
280_20204D4F4E535445
290_5220373936202030
201_0080000000000000
010_C800000000000000
020_0000084FA1000000
028_0
"Vin = 0060114024 "
"DTC = 10115805017520048560D60200D60000D60400AAAAAA"
"047C2856"
060114024hard :QD0A3010
soft :A3IU1NEI
Ciganek1
Post by Ciganek1 »
What's the problem?
all is ok on cables and registration
you can try to unplug batery for 5 minutes , and give it a new try
Ciganek1
Post by Ciganek1 »
Disconnecting the battery for 30 minutes didn't help either.
when you press reset button , the leds are blinking on the obd device ?
Ciganek1
Post by Ciganek1 »
Yes, the lights are flashing but the service key still remains on the display.
elem
Post by elem »
same problem on M696 ABS 2010, do you fix it?
