2020 Diavel 1260
Silentkr4ken
2020 Diavel 1260
Post by Silentkr4ken »
Hi
I'm able to connect to the bike, although it shows VIN it shows no ECU type. It also shows the bike as 2019 but not sure that matters?
I sent off for a licence and got it back (blue "get licence" button has now disappeared). I try to reset the annual service but nothing works 😔
I have a 2020 Ducati Diavel 1260
Silentkr4ken
Re: 2020 Diavel 1260
"File generated On 23/03/2025 19:57:10"
"Auto Detect Bike = Diavel 2019"
"User Bike = 2020 Ducati Diavel 1260"
"Hardw = """
" vin 145A8F035A444D4745303041414C42303034313736
020_0000790000004B7B
024_0000000020000674
080_19F2BC033000066E
100_C706043041000609
018_0002A00064004DA0
019_9609600000030EA1
188_7FEF7C53800F4B85
022_000000000003FB6E
023_000000007FC70BD1
240_0000012900116DC6
174_EC7F004B386A0A11
178_FA7F0530096C0A6B
17C_EA7F0100B4790AB0
"Vin = ZDMGE00AALB004176"
"807B16FA"
ZDMGE00AALB004176
all looks ok to me
you have not much data displayed ,it means i have to improve melcodiag
other functions shall works
JohnDeere01
Post by JohnDeere01 »
Check you are actually clicking the correct button for what service you want cleared.
I thought it was not working for me, then I realized I was clicking the Oil Service Reset button NOT the annual service button (2018 1260s Multi)
Max999
Post by Max999 »
I have diavel 1260S 2022. Reset of PIN is not working. In the report shows "CAN ERROR" (I have 6 pin connector). What it means and what can I do?
it means i maybe not sending the right command for your bike or i simply cannot send it cause it could be key protected and i don't have the key algorythm yet
for the can error, your elm return it cause its buffere is prolly flooded , if you can see some data like VIN , it's not a big deal
Silentkr4ken
JohnDeere01 wrote: Sun Mar 30, 2025 4:03 pm Check you are actually clicking the correct button for what service you want cleared.
Yes I'm definitely clicking the annual service button
Silentkr4ken
jpl250rs wrote: Sun Mar 30, 2025 10:01 am all looks ok to me
What's that mean?
Does that mean the cable is working?
What's the next steps/plan?
Silentkr4ken
viewtopic.php?t=71
In that topic someone seems to have the same issue as me and you've said MelcoDiag can't determine the bike, however on mine you've said everything is fine 🤷🏻‍♂️
Is mine fine despite having the same blank ECU type & hardware as displayed in the screenshot on the above topic?
I'm trying to figure out firstly is the cable I have working?
Secondly is MelcoDiag meant to be able to service reset a 2019/2020 Diavel 1260? If so then what's going wrong?
yes your bike is fully recognized "Auto Detect Bike = Diavel 2019"
and i don't know yet why you can't succeed to reste , maybe i need to fix something, but i don't know what
