Good afternoon! Thank you for sending the license promptly. The program has been activated. Service intervals have been reset. However, data on the condition of the motorcycle (transmission, RPM, mileage, etc.) is not reflected correctly. The DQS error could not be counted. when errors are requested, the program turns off and turns on the ignition, and the error disappears and is not reflected in the error list when it appears again.
n the DTC tab, when trying to read the error code, the program turns off and turns on the ignition of the motorcycle. At this point, the error codes disappear. I tried to take a video.https://disk.yandex.ru/i/DbW8fdiS9fTYVw
When the "Scan DTC" button is pressed, the program initializes the engine block itself. This happens in 1 sec. No action is taken on my part after pressing the "Scan DTC" button.
