Gear learning
Richoxford
Gear learning
Post by Richoxford »
Ducati scrambler cafe racer 803 2019
Hi just joined , really good forum lots of info . Lots of bikes but me first Ducati and I am loving it. Bought it very low mileage but 2019 so needed belts did them .. followers need attention belts well slack but running like a dream now . Bike never really shown N since I got it properly. Dealer happy to have a look but quite a trot and to be fair I wanted something to tinker with. Replaced gear selection cable as cable was trapped thought might be worth it still the same . Downloaded melcodiag .. cables with blue tooth a little twiddley but me being a twat. Got license all fired up vin extr . Some function .. can see side stand operation .. some reason thinks clutch is pull when it’s not. Know that ok cause won’t start without it pulled in . But try as I may can get the flashing C. Can see blue tooth polling but nothing .. shame whole thing is really well thought out and once setup seems great for free software .. but just won’t start gear sequence .. any ideas please .. I can take it to the dealer but quite enjoying the challenge.. Regards Rich
Re: Gear learning
Richoxford
Re: Gear learning
I will do thanks .. not sure how too but will work it out
Richoxford
Re: Gear learning
Here you go hope it helps .. getting hang of software its really good but just can’t make the gear learn work .. not sure about the others .. using blue tooth . Wondered if cable be better .. it does read all ecu info .. thanks in advance… Rich
"File generated On 09/09/2026 19:28:18"
"Software version 2.0.5.3"
"User Bike = cafe racer 803 2019"
"Ecu = 5WY8691-AA"
"Hardw = QD0J3010"
"Softw = 1QABBAD1"
" vin:100E5A8C3430303021333630303536202220AAAAAAAAAAAA
9 PIDS active founds
100_5100FF0000020000
023_000000007EEE081A
081_00000000C8000000
188_7FEF80D381034923
020_0000C00000000000
174_EE7F004AE66C0589
178_0E8003361C6805AD
17C_1280010019820560
"Vin = 4000360056 "
"C6F05BE4"
000360056hard :QD0J3010
scrambler detected
soft :1QABBAD1
Re: Gear learning
ok great ,
i don't know any gear reset command on the m3c ecu , do you have a service manual where it's written to use the diagnose tool to make a gear reset ?
Richoxford
Re: Gear learning
I replaced the sensor and symptom still the same I can’t find anything specific but asume it must be a diag for gear learning .. there is no user command .. not sure how else would you calibrate.. is there a dealer level command that can’t be accessed .. cheers
Richoxford
Re: Gear learning
Found this if it helps ..The strongest evidence I found for the later-generation/MY19 system is the OBDSTAR bulletin: it explicitly demonstrates gear learning on a MY19 Ducati using a dedicated diagnostic routine.
