Gear learning
Richoxford
Gear learning
2019 scramble .. hi any of you guys done gear relearning .. does it require dealer tool .. cheers
Re: Gear learning
try this version by replacing the actual exe
be sure all dll are unlocked and in the same directory.
press reset gear button and send me the debug report . i'll try to add this function
Richoxford
Re: Gear learning
Thanks very much I’ll do it now cheers
Richoxford
Re: Gear learning
"File generated On 12/09/2026 14:55:48"
"Software version 2.0.5.3"
"User Bike = cafe racer 2019 803"
"Ecu = 5WY8691-AA"
"Hardw = QD0J3010"
"Softw = 1QABBAD1"
" vin:100E5A8C3430303021333630303536202220AAAAAAAAAAAA
300_2DB100000B26820E
029_0000000000080000
360_0000001209260000
100_5100FF0000020000
020_0000C00000000000
081_00000000C8000000
022_000000000003FA73
023_000000007EAE0ACA
188_7FE7807381374B80
174_EE7F0050296D065A
178_0E800331CE670666
17C_F47F01006C810698
"Vin = 4000360056 "
"C6F05BE4"
000360056hard :QD0J3010
scrambler detected
soft :1QABBAD1
I connected it up pressed the gear learning button then did the debug .. hope this helps. Thanks Rich
"Ecu = 5WY8691-AA"
"Hardw = QD0J3010"
"Softw = 1QABBAD1"
"Vin = 4000360056 "
"C6F05BE4"
scrambler detected
soft :1QABBAD1
Richoxford
Re: Gear learning
Sorry missed the first bit I’ll do again cheers
Richoxford
Re: Gear learning
you are a legend it works ill let you know how i get on thanks so much
Re: Gear learning
Good news
there is not the debug data I’m waiting for btw
Richoxford
Gear learning
I will send the other debug info.. with that version it definitely works vs on a 2019 cafe racer and initiates a flashing C starting the whole sequence. I’m an idiot so it took me a while to program in the details but it’s working. Thanks for all your hard work and an amazing piece of software. I’ll ping something over on PayPal .. and support the software when I can .. legend !!!! Kind regards Rich ..
