I successfully connected to my by hyperstrada 821 over a bluetooth adapter. It would have been great to be able able to activate the heated grips. I have just installed some but I believe that I need to go to the dealer to have them first activated in the ECU. I was hoping that Melcodiag could do this but clicking on the button "grip heat ON" on the "active tests" tab mad the adapter blink, but nothing happens after that. I disconnected, switch the bike Off and On again but unftortunately the feature is not activated.
This is my report from Mecodiag, maybe someone sees something or has a trick to activate them?
"File generated On 16.02.2026 15:58:18"
"Auto Detect Bike = Hyper 821"
"User Bike = hyperstrada 821 2014"
"Softw = 12"
" vin 145A8F035A444D4232303041414542303037393932
020_03000E03D6003700
120_840B010000000402
024_A657972600000000
080_00108430000000C8
018_0000420000000003
230_00000000000
"Vin = ZDMB200AAEB007992"
"322907FF"
ZDMB200AAEB007992
Activate heated grips for hypermotard/hyperstrada 821
Re: Activate heated grips for hypermotard/hyperstrada 821
you shall see the elm blinking when you enable grip right ?
have you tried to click grip off ? ( in case i crossed the command)
thanks for the reply!
Yes, the ELM blinked multiple times. I only tried multiple times the "ON".
Will try the "Off" and report again.
no, unfortunately, the "off" command does not work neither.
I tried multiple series:
Off only, did not work
clicked back on ON, but did not work.
Moved back to Off, still does not work.
Latest version of Melcodiag enabled my heated grips on my '14 hyperstrada 821!
Well done!
Merci infiniment!
(Cable Lonelec bluetooth with ELM 1.5)
Well done!
Merci infiniment!
