Hi!
So I connected my computer to the motorcycle with Melcodiag running, and when I click on "get license", all I get is a never ending loading screen on the browser, and on Melcodiag, the ecu type goes from "blank" to "no ecu data" as I click on "get license". On Melcodiag, I can see my bike, VIN, kms, Software version and ELM V voltage. I am using the same Com channel as my adapter (COM4).
This is the interface I am using : https://www.amazon.ca/dp/B07MQ8GHG3?ref ... asin_title
This is the adapter I am using : https://www.amazon.ca/dp/B0FN3F3B8N?ref ... asin_title
This is the log I get when clicking "Write report" :
"File generated On 14/09/2026 4:48:45 PM"
"Auto Detect Bike = 2013 Hypermotard 821"
"User Bike = 2013 Hyperstrada 821"
"Hardw = ↕"
"Softw = 12"
" vin 145A8F035A444D3159425453364442303032373735
8 PIDS active founds
018_00005A0000000003
020_0400FF03BE003700
080_00114430000000C8
024_901EC2BB00000000
160_C8C800006564C2C1
150_0000535057504003
100_801208377937CE00
"Vin = ZDM1YBTS6DB002775"
"4000A6D3"
ZDM1YBTS6DB002775
ZDM1YBTS6DB002775
Any help would be appreciated, Thank you!
"Get license" button not working
Re: "Get license" button not working
Hey, thanks for the cue.
It seems to have worked and I've been able to add the license, but the program seems to be only partially working.
I can scan and delete codes, reset dash pin (did not try the service resets yet), interact with the dash in the active tests, do the fan/fuel pump tests, and some other stuff.
However, some parts don't seem to work
Main page : I do not see ECU information (written N/A in ECU type and software version, and nothing in hardware version), nor the temp data.
Active tests : Exhaust valve position 1 and 2 doesn't activate anything (I hear it on ignition on normally)
Passive tests : Only ones I've been able to see are the tc level on the first box, brake switch on the the third and I also see TPS angles V and H
Is this a pebcak moment or is there more to it?
I will make a fonction for finding more data
Reset shall be ok
Reset shall be ok
