I have an issue with MelcoDiag on my Ducati Multistrada 1200 (2010) with Melco ECU.
The program connects fine, I can read and clear error codes, and basic functions work correctly. However, when I try to use an active test (for example, set the speedometer to 50 km/h), the value is shown on the dashboard but then the program freezes and stops responding. I have to restart the software after that.
The license is activated and all functions should be available.
The battery is fully charged and on a charger during diagnostics.
No error codes are present in the ECU.
Windows drivers for the FTDI cable are installed and working properly.
At the program start, it is possible to select two model years: 2011 and 2012. I have tried both options.
Has anyone experienced a similar issue or have any advice on how to fix this?
Thank you for any help!
"File generated On 24.05.2025 17:52:37"
"User Bike = MTS1200/2010(2011)"
"Ecu = 070159538"
"Softw = 00000007"
" vin DATA
vin 037F1A11
vin 7F1A31
vin 31A8FD07F1A31
020_0000005154800000
080_06000000C8000006
018_000056000000C801
110_8032580440000E10
300_A406816507415400
230_0000000000000000
"F2632F93"
"Bike = 6"
Multistrada 1200 (2010) - active test
Re: Multistrada 1200 (2010) - active test
I have tried these two cables (see photo): one is a USB ELM327 v1.5 cable with a 4-pin Ducati adapter, and the other is a Bluetooth ELM327 v1.5 adapter. Both connect to the ECU, but when I try to activate an actuator or run an active test, MelcoDiag freezes or becomes unresponsive.
FTDI drivers are installed, the COM port is detected for the USB cable, but the issue is the same with both adapters.
Has anyone experienced this problem? Could it be related to the cable version or type? Would replacing it with another specific model help? Thanks for any advice!
- cables.JPG (21.22 KiB) Viewed 5383 times
it's not a big issue , and i don't think it's related to the elm.
it's certainly because there is an answer from ecu that it not handled yet , but that don't avoid the action to be completed
wayne90782
Hi
I use ELM327 1.4 and I have the same problem as the 2012 Multistrada 1200S
"File generated On 6/17/2025 8:29:37 AM"
"User Bike = multi1200S/2012"
"Ecu = MELCO HIMEJI "
"Softw = 00080003"
" vin DATA
vin 037F1A11
vin 7F1A31
vin 31A8FD07F1A31
020_0000000000000000
018_0000460010007859
110_002D580440008E20
300_050881389A338100
"F804108B"
"Softw = 00080003"
" vin DATA
vin 037F1A11
vin 7F1A31
vin 31A8FD07F1A31
"F804108B"
