Melcodiag and license.
Re: Melcodiag and license.
try to unlock the cle.lic file
right click on cle.lic and choose properties , untick unlock ..
luerira1
Post by luerira1 »
Hello again, friend.
I've already unlocked the license file, unfortunately, it didn't make any difference.
Today, I tried again to connect to the motorcycle and trace the fault code it's displaying, but it wasn't possible; I can't read any codes.
What else could I do?
What am I doing wrong?
Sin título1.png (51.55 KiB) Viewed 7572 times
Sin título.jpg (92.66 KiB) Viewed 7572 times
unlock cle.lic in file properties , and give melcodiag admin rights
luerira1
Post by luerira1 »
It didn't work, it still doesn't let me see the check engine light fault code...😭 I have Windows 11, couldn't that be the problem?
windows 11 is fine
luerira1
Post by luerira1 »
Finally, it worked!!!!
With the new license file you sent, I was able to access my fault codes and reset the 12,000km service interval.
Thank you so much, my friend. I'm so glad it worked, and it's all thanks to you.
Truly, thank you so much.
