Integer is not valid
Robertbenson30
Re: Integer is not valid
Post by Robertbenson30 »
jpl250rs wrote: Tue Aug 26, 2025 9:18 am great so let's plan a schedule and get connected with rustdesk when ever you can
Sounds good. I'm flexible and can do the remote this evening if you are available. Not sure what time zone you are in, I'm MST.
from now untill the end of this hours it's ok for me it's 9:12 pm actually
Robertbenson30
jpl250rs wrote: Tue Aug 26, 2025 7:12 pm from now untill the end of this hours it's ok for me it's 9:12 pm actually
PM sent
yes i got it , but you are probably at work now
cds31
Post by cds31 »
I also get the same error when Melcodiag v 2.0.4.8 (the latest download) is run; I just tried it after previous versions 2.0.3.7 and 2.0.4.6 which startup (still needing an OK on a visual basic prompt) and connect OK, but the reset buttons are not active despite lic.cle present (will open another thread on that).
My bike / PC / ELM device
- Scrambler 800 2109
- Windows 10
- Lonelec Bluescan v1.5
thanks for the capture , i think i found the error , you can download it again and make a new test
cds31
Post by cds31 »
I have just tried the latest Melcodiag from the DOWNLOAD (v 2.0.4.8)
- It starts up OK now - there is no longer the error "conversion from string to type integer not valid".
- I am unable to confirm whether resets work (as I already did my annual earlier with the previous version); note however, I was unable to activate any "button" on the DTC tab (e.g. Scan for ECUs), and on the Resets tab the only buttons that seem to be active are "Key reset" and "Gear reset" : not grayed like the other ones, and turn brighter when the cursor is over them.
Thanks for your work.
thanks for the feedback
it looks like the cle.lic is not valid or locked .
this can be checked in the debug report file
cds31
Post by cds31 »
at the end of the debug report :
000357929hard :QD0J3010
scrambler detected
soft :1QABAAD1
(I have the whole report if needed);
What do I need to do to unlock the cle.lic ? if that is the cause
try to register again , maybe the cle.lic is not correct
