No license received
Aella
Re: No license received
Post by Aella »
"File generated On 6/03/2022 5:50:58 PM"
"Software version 2.0.0.6"
"Auto Detect Bike = Panigale 899"
"User Bike = 2014"
"Main ecu is not detected"
"BBS ecu is not detected"
"DashBoard ecu is not detected"
"Ecu = DNPBT000643"
"Hardw = J011"
"Softw = 08000402"
8 PIDS active founds
080_04060606000000C8
024_8680AA0802800C00
240_A293C00000A8A200
018_00005A0000000001
020_00000000FFFF0000
230_0000000000080000
680_0601B00000000000
"Vin = ZDMH803AAEB021468"
"DTC = 10115805100022061524100228900028501228000000 10115805100022061524100228900028501228000000 10115805100022061524100228900028501228000000"
"46BABF66"
Did this today.
don't you register in june already ?
what message the server tell you when you are trying to register ?
Aella
Post by Aella »
I applied in June and didn’t receive one and then logged back in again and it said I had already applied and had to wait
Aella
Post by Aella »
Thank you have received license,
Aella
Post by Aella »
Hi I have been having trouble trying to rest TPS,
When I connect the bike to the laptop, start the software up.
Navigate to the correct menu to recalibrate the TPS’s
Press the recalibrate TPS button I can hear it do it thing.
After it has finished I go to main menu press the disconnect tab,
Then turn the bike off then start the bike runs good,
I leave it for a couple of days or the next day and starts the bike up and rev to 3000 rpm,normally the bike should idle @1400 rpm
You still have 5 DTC recorded ?
Aella
Post by Aella »
Hi Thanks for getting back to me,these are the DTC i can't clear them
0 Defaults recorded on 7E2
*Ecu found on : 7DF ,7E9
*Ecu found on : 7D0 ,7E8
*Ecu found on : 7D1 ,7E9
*Ecu found on : 7D3 ,7EB
*Ecu found on : 7D4 ,7EC
none on 7e2 , you shall check the other ones
Aella
Post by Aella »
plug the laptop into the bike this morning after pressing [DTC on 7E2: 7EA]
the list of errors had gone the only message on there was, O defalts recorded on 7E2
this is befor starting the bike up.
Aella
Post by Aella »
started the bike up this morning rev to 3000rpm, is the old program available for down load ?
check DTC 0 defalts recored on 7e2
