my bike info does not populate in the software?
Re: my bike info does not populate in the software?
hmm that's strange , cause you shall use any bike options.
if you use m3c option you may corruput or loose your racing UMAP if you have one loaded .
2014mts1200bob
Post by 2014mts1200bob »
Still no luck with oil service reset. everything populates as it should. I'm connecting with the any bike option I can clear and reset the pin code. when I hit the service reset or desmo reset the data transfer lights flash on the obd adapter but nothing happens with the software and no changes happen with the motorcycle. do you have any other recommendations?
"File generated On 11/16/2025 4:18:49 PM"
"Auto Detect Bike = MTS1200"
"User Bike = MTS 1200 2014"
"Ecu = MELCO HIMEJI "
"Softw = 00020302"
" vin 145A8F035A444D3132425357304542303130333030
9 PIDS active founds
018_00005E0000000004
080_04000600000000C8
020_0500004842000000
024_0A374A2300000000
022_0000000000000000
240_8170D000002A9B00
110_A032580440000E00
300_660284008AAD0540
230_0000000000080000
"Vin = ZDM12BSW0EB010300"
"3271D8F1"
ZDM12BSW0EB010300
if you can setup a remote connection , i can try different commands
your model has been successfully resetted , so i'm confidenty
