2016 MTS 1200 DVT
Greefy67
Re: 2016 MTS 1200 DVT
Post by Greefy67 »
Should I try a different software?
ran-ran
Post by ran-ran »
Hi there,
I have the same issue on my 2015 DVT, it also has the 10S software (the software on the bike).
One thing I have noticed, if you change the date on the bike, then run the Melco (2.0.4.9) and select get service date then it returns the date you have set on the bike - not sure if its getting todays date rather than the service reset date. Not sure if this might help?
Cheers,
Rich
Ltwin821
Post by Ltwin821 »
As the software doesn't work on my MTS. Ive resorted to changing the date on mine to remove the service light. You need to take the date back to when it was last reset.
:idea: good tips for others
ran-ran
Post by ran-ran »
Ltwin821 wrote: Wed Mar 04, 2026 5:22 pm As the software doesn't work on my MTS. Ive resorted to changing the date on mine to remove the service light. You need to take the date back to when it was last reset.
:D Thats exactly what I ended up doing with mine!
