Page 2 of 3
Re: Unable to reset Desmo Service on 2015 Scrambler
Posted: Wed Aug 12, 2026 3:46 pm
by Arno83
the installer often locks dll when installing. It was the case for me. So, you can do anything in a reading mode, like reading error codes, but you cannot do resets.
Go to melcodiag directory, choose dll files, right click, properties, general and go straight down to tick "unlock" box. Do this for both dll.
It worked for me. 800 MY 2015 classic scrambler.
Good luck !
Posted: Wed Aug 12, 2026 3:51 pm
derek996 wrote: Wed Aug 12, 2026 11:53 am Why would the installer install locked files?
there is no installer .
depends where you unzip the files , windows lock the files itself if you drop them in a folder you havent the full rights .
it shall not be lock if you unzip on the desktop or c:\users\yourname\mydocuments
Posted: Wed Aug 12, 2026 5:47 pm
by derek996
I think that may indeed be the problem. Both .dll files were "blocked". I have now unblocked them and will try again tomorrow.
Posted: Thu Aug 13, 2026 12:37 pm
by derek996
Tried again with .ddl files unblocked. No difference, still can't reset the desmo service.
I then completely uninstalled all of the Melcodiag stuff and did a clean install from the zip file into the Documents folder. Put the lic.le file in the same folder, made sure the .dll files were unblocked and tried again. No difference. Still cant clear service light although some of the passive tests work.
This is the debug file;
"File generated On 13/08/2026 12:32:31"
"Software version 2.0.5.2"
"User Bike = 2015 Scrambler Classic"
"Ecu = 5WY8691-AA"
"Hardw = QD0G1010"
"Softw = 1CABAAG1"
" vin:100E5A8C3430303021313130303331202220AAAAAAAAAAAA
4 PIDS active founds
081_00000000C8000000
022_0000000000000C96
020_52B8C00000000000
100_00000A0000000000
"Vin = 4000110031 "
"1AB4FDC8"
000110031hard :QD0G1010
scrambler detected
soft :1CABAAG1
scrambler detected
soft :1CABAAG1
Posted: Thu Aug 13, 2026 12:43 pm
i'd need to check remotly cause everything is good to me
Posted: Fri Aug 14, 2026 10:38 am
by derek996
Would it be worth trying M3C9? Although it seems too need a different licence file.
Posted: Fri Aug 14, 2026 1:46 pm
no chances with m3c9 and the scambler . it's only working on melcodiag
i'd be curious to check on your computer what's wrong
Posted: Fri Aug 14, 2026 3:44 pm
by derek996
"i'd be curious to check on your computer what's wrong"
So would I. I tried again today with a Bluetooth ELM327 that I borrowed from my son and got exactly the same results. Can't reset service light but can test fuel pump, headlight, speedo and tacho. I'm hoping to borrow my son's laptop the next few days to try with that, is running Windows 11.
As I said earlier I never had any issues with my old Laptop and Windows 95.
Posted: Fri Aug 14, 2026 4:23 pm
if the test are working , it is not a computer issue .
you shall have the microsoft framework 4.8 installed
you can retry with the 2.0.5.3 , i had some debug message in the bottom of the screen
Posted: Mon Aug 17, 2026 5:52 pm
by derek996
I tried with 2.0.5.3 today. Still can't reset the service light.
I did notice that the headlight test didn't work nor did the speedo test but when switching on the RPM it also turned on the headlight. 2.0.5.2 might have been the same, I can't be sure.
