2020 Diavel 1260
Re: 2020 Diavel 1260
BT version works as fine as the usb version
Silentkr4ken
Post by Silentkr4ken »
jpl250rs wrote: Wed May 07, 2025 9:04 pm BT version works as fine as the usb version
Thanks 😎
I have a 2020 Ducati Diavel 1260
Silentkr4ken
When the cable arrives what's the best way to confirm the responses back to the software are 'sane'?
if you get the vin and other ecu informations right away at each connection that sould be ok
Silentkr4ken
jpl250rs wrote: Thu May 08, 2025 9:22 pm if you get the vin and other ecu informations right away at each connection that sould be ok
It did that with the last cable I had but when you remoted on my laptop and were sending codes/instructions you said it was returning weird responses. How can I test that the new cable is not?
you can send 021001 in debug mode on the eu 7e2 and check if the answer is 0150 , or 025001
Silentkr4ken
jpl250rs wrote: Fri May 09, 2025 5:16 pm you can send 021001 in debug mode on the eu 7e2 and check if the answer is 0150 , or 025001
Remind me how you get into debug mode?
Silentkr4ken
Yeah the new Lonelec cable seems to work fine 😎
I don't suppose you've been able to figure out what's stopping the service resets from working?
no not yet
Silentkr4ken
