Page 4 of 5
Re: 2020 Diavel 1260
Posted: Wed May 07, 2025 9:04 pm
BT version works as fine as the usb version
Posted: Thu May 08, 2025 6:26 am
by Silentkr4ken
jpl250rs wrote: Wed May 07, 2025 9:04 pm BT version works as fine as the usb version
Thanks 😎
Posted: Thu May 08, 2025 8:51 pm
by Silentkr4ken
When the cable arrives what's the best way to confirm the responses back to the software are 'sane'?
Posted: Thu May 08, 2025 9:22 pm
if you get the vin and other ecu informations right away at each connection that sould be ok
Posted: Fri May 09, 2025 4:00 pm
by Silentkr4ken
jpl250rs wrote: Thu May 08, 2025 9:22 pm if you get the vin and other ecu informations right away at each connection that sould be ok
It did that with the last cable I had but when you remoted on my laptop and were sending codes/instructions you said it was returning weird responses. How can I test that the new cable is not?
Posted: Fri May 09, 2025 5:16 pm
you can send 021001 in debug mode on the eu 7e2 and check if the answer is 0150 , or 025001
Posted: Sat May 10, 2025 7:44 pm
by Silentkr4ken
jpl250rs wrote: Fri May 09, 2025 5:16 pm you can send 021001 in debug mode on the eu 7e2 and check if the answer is 0150 , or 025001
Remind me how you get into debug mode?
Posted: Mon May 12, 2025 11:16 am
by Silentkr4ken
Yeah the new Lonelec cable seems to work fine 😎
I don't suppose you've been able to figure out what's stopping the service resets from working?
Posted: Mon May 12, 2025 4:07 pm
no not yet
Posted: Sun Sep 28, 2025 7:44 am
by Silentkr4ken
