I have read in the forum that the dealers do this when these symptoms present.  Also a lot of people state it helps.  I don’t know, it is worth a try I guess. Do you know if the software/ cables work for windows 11? Also thanks for the work you have done and are doing a lot of people appreciate it!
I found this instructional on a forum, does this seem accurate?:
1. Buy the correct cable(s), search eBay for an "ELM 327 FTDI cable and 4 pin Ducati cable" and buy both cables as a package for around £33. It has to be ELM chipset, don't get anything else. (I thought I already had the correct FTDI-OBD2 cable - I didn't!)
2. Google "VCP drivers FTDI" and download the Virtual Com Port drivers file and install them on the PC before you plug in the USB FTDI ELM 327 cable you just bought. You also need ELM327 v1.5 software driver - it might come with the cable on a disk, otherwise download and install it on the PC
3. Using Windows Device Manager check or set your COM port listed to 38400 bps.
4. Download JPDiag MelcoDiag software from here
5. Start MelcoDiag - set MelcoDiag button on the opening screen to M3C
6. Follow the instructions to get a FREE licence - a key file is sent to you as an email attachment within a couple of hours and you load the key into the MelcoDiag folder and restart MelcoDiag. The screen will tell you that an email has been sent to gift you a FREE license (it arrives as a lic.cle file which is pertinent to your VIN number and ECU code)
7. Copy the lic.cle file into the same folder as the MelcoDiag software.
8. Plug in the USB FTDI OBD2 cable to the PC, remove the scrambler seat, remove the plastic battery cover with the one 4mm Allen bolt. Then locate the 4 pin diagnostics plug under the plastic battery cover next to the USB port. It is a black cable with a connector on the end. lift the plastic tab on the connector to remove the plastic cap and plug the second Ducati cable into the OBD2 cable and into the now exposed Ducati 4 pin diagnostics plug on the bike.
9. Start MelcoDiag once you have the licence key (lic.cle) file loaded into the same file directory as the MelcoDiag folder
10. Turn on the bike ignition and then press Connect on the MelcoDiag Home tab. The lights on the connect button should go green on the MelcoDiag screen under the Connect button and all five lights on the cable should flash at some point.
11. If you get a error message saying ELM software not detected, you have bought the wrong cable - start again on eBay. (I should know, I did this first of all)
12. If everything is green on the screen under the Connect button, set MelcoDiag on the opening screen to M3C
13. Open the Reset Tab on MelcoDiag and click the Desmo service reset button once. Wait for the corresponding 'ding' sound (up to 5 seconds later) and then turn the bike ignition off.
14. Wait 15 seconds and turn on the bike ignition. Hey presto, the service indicator is now set to another 7500 miles. Yippeeee!
15. Make a donation to the JPDiag PayPal address to show your appreciation for all his hard work and for saving you a small fortune for not having to visit the Ducati dealer to reset the service mileage after a simple oil and filter change.
