Multiple licenses on the same computer
Posted: Thu May 29, 2025 7:22 am
by Erre
In one of the threads someone asked if it was possible to have several Melco licenses on the same computer, JP answered that he could unify them into a single license, but my question is, if I place a license in the Melco folder and run the program and then remove the license and place the other one, and run the program, will it work?
Re: Multiple licenses on the same computer
Posted: Thu May 29, 2025 9:58 am
yes it will work , if you don't rename the lic file , it's just a pain for you to change it when you connect a different bike
Posted: Fri May 30, 2025 7:42 am
by Erre
No, no, I won't change anything, and I don't see it as a nuisance either. It's just a matter of leaving each license in a folder with the bike's name. In any case, I only have three Ducatis, so it won't be a problem.
Thank you very much, my friend JP.
Posted: Fri Aug 22, 2025 3:53 am
by DESMAN
Can explain me how to unify two licence in just one file. I have two bikes with two lic file, and would like work without copy/paste trick every time
Posted: Fri Aug 22, 2025 5:55 pm
inside a terminal you can type this
copy /b cle1.lic + cle2.lic cle.lic
you will have to renanme the2 files one cle1.lic , the 2nd one cle2.lic .
both will be merged into a single one
Posted: Thu Aug 28, 2025 8:54 am
by DESMAN
ok I will try by terminal , but , the procedure is valid for two .lic files and also for more than two ? having four bikes on the box now..
Posted: Thu Aug 28, 2025 8:01 pm
up to 5
