TPS reset on Ducati Hypermotard 821 2014
Votong
Post by Votong »
Hi JP, with all my heart I thank you so much for creating these wonderful things.
i have successfully reset the oil service and desmo on my ducati hypermotard 821 2014 using ecu 7sm. and i want to ask you if i can reset the TPS through this tool? i am having problem with the TPS parameters on the “test” page in the software. there is a huge difference between the 2 TPS sensors.
I will keep you updated on what works on your software.
Once again, I sincerely thank you for your dedication.
Re: TPS reset on Ducati Hypermotard 821 2014
tps reading function has never been debugged with your bike , don't trust it too much.
by the way the TPS reset button shall be active and working
Votong
Post by Votong »
My car is currently reporting an engine fault with the P0150 error code (problem with the exhaust sensor in the vertical machine) although I have replaced the new sensor also measured the parameters of the sensor terminals to check and it is good. (eliminating problems related to the wires and connectors because I have checked them) currently the car is in safe mode - I cannot go over 4000 rpm when rolling.
after many checks through your software, I noticed that the TPS of the two machines are different (picture) so it makes me think about resetting the TPS but the software has no response like when I reset the oil service.
by the way, the functions such as fan test, injector test, throttle motor test, electric throttle sensing work well.
- TPS V: 29
- TPS H: 8
