				2021 Desert Sled issues
				Posted: Thu Jun 12, 2025 6:52 am
				by Mr Fox
				I've been trying to reset my annual service on the sled as well as the desmo (although the light is not yet popped up, but i've done the job so).
I am using
https://www.lonelec.com/product/obd2-wi ... ader-v1-5/ and am able to connect to it via Melcodiag. I am not able to pull a report to get a license with "M3C" ticked, only with "Any bike" selected, sent that and received the license yesterday. Tried resetting but it does not work.
I can connect and read the VIN and it is correct but it does not seem to provide proper "ECU Type" or "Hardware version" with "Any bike" ticked
I had one session where it connected with M3C and read "CAN ERROR" ECU type, VIN and so on.
Any idea of what could be wrong?
And sorry JP! I sent an email before reading that this should be way of communications.
				Re: 2021 Desert Sled issues
				Posted: Thu Jun 12, 2025 7:57 pm
				can you post the report with each of selected mode ?
				Posted: Thu Jun 12, 2025 8:57 pm
				by Mr Fox
				Any bike:
"File generated On 2025-06-12 22:57:31"
"Auto Detect Bike = Ducati Scrambler Desert Sled 2021 EU5"
"User Bike = 2021"
"Hardw = """
"Softw = 22000000"
" vin  DATA
 vin  DATA
 vin 7F1A11CCCCCCCC
 vin 7F1A22
 vin 31A8F03145A8F035A444D354B303041414D42303030383033
020_004000100000072C
02A_000180000000073C
174_0080005B496B0C53
178_0480000037690C74
17C_0080010019800C0E
024_0000000000060398
188_7FFF7FA780C34129
022_000000000003F1BC
18C_800380020000025F
023_000000547F430118
080_2BC2BC1F00000388
100_C802000FFF0012BA
"Vin = ZDM5K00AAMB000803"
"C6F341C2"
ZDM5K00AAMB000803
ZDM5K00AAMB000803
And M3C:
"File generated On 2025-06-12 22:56:32"
"User Bike = 2021"
" vin:NO DATA>
020_0040001000000ED9
02A_0001800000000EC9
080_2BC2BC1F00000B60
100_C802000FFF001A52
188_80037FA380C3471F
022_000000000003F7F2
18C_800380020000088D
023_000000547F47077B
174_FE7F005A306B0551
178_0C80082D226905B0
17C_00800100138005F4
300_3B8000080B02CF43
230_0000100000000F5F
220_0000000000000FB1
"C6F341C2"
ZDM5K00AAMB000803
				Posted: Fri Jun 13, 2025 4:38 pm
				i'mnot sure your bike has a continental ecu M3C , can you confirm it ?
else for the light reset you may need to wait the  light comes up
				Posted: Fri Jun 13, 2025 7:48 pm
				by Mr Fox
				So from your side it is looking ok?
The yearly service is showing up, but I can not remove it.
Image below shows picture of the ECU, not sure if that helps?
https://share.icloud.com/photos/0d6r6K_ ... zJBgS5VGBQ
				Posted: Sat Jun 14, 2025 8:34 pm
				yes all looks ok
 it's not a m3c  but i don't know the made
				Posted: Sun Jun 15, 2025 4:47 am
				by Mr Fox
				Glad to know I’ve done it correct at least! So that means I can not reset the service light, or should ”any bike” work?
				Posted: Sun Jun 15, 2025 6:16 pm
				i think any bike is the right option.
we can try different settings / resets by changing the bike model manually
i'm sending you some instructions
				Posted: Sun Jun 15, 2025 9:25 pm
				by Mr Fox
				Awesome, thanks! I’ll try it as soon as I can
				Posted: Sun Jun 22, 2025 5:12 pm
				by Mr Fox
				I’ve tried all the bike models but no luck. And it is “service intervaI” I should reset, right?
 can see the OBD reader sending/receiving but nothing. Is there any indication from Melco when it should be a success?
Could the issue be that I did not tick “oil service active” when I requested the license?
