MTS V4S 2021 annual reset issue.
PaulMTS_V4S
Post by PaulMTS_V4S »
Hi JP,
I have successfully connected the Melcodiag app to my bike but when pressing the 'annual service' button the command seems to be issued but nothing happens and the light remains on.
Can you help me out on this? Thanks, Paul.
The MelcoDiag.exe.debug log file reads:
"File generated On 6/15/2025 9:09:56 AM"
"Auto Detect Bike = MTS V4S"
"User Bike = MTS V4S / 2021"
"Hardw = """
" vin 145A8F035A444D3141303041414D42303039363832
022_000000000003FC3D
023_000001FC7FC70CF4
020_0040D91068008DCB
184_7D0B8F6300000C83
188_7FFF7CEF804B4C8D
018_0002A000C40041CC
019_96096000000001CE
18C_800B7FFF80030C89
024_0000000000000117
084_1D22261226005F03
080_1D2226C045200171
100_C80205C05A000022
130_C155040101C00B64
"Vin = ZDM1A00AAMB009682"
"565E6298"
ZDM1A00AAMB009682
***reset annual***
065001006400C300
service date : 250615
***reset annual***
065001006400C300
***reset annual***
065001006400C300
***reset annual***
065001006400C300
***reset annual***
065001006400C300
ZDM1A00AAMB009682
Re: MTS V4S 2021 annual reset issue.
all looks ok ,
for the annual there may be some issues yes , the dash board requiere a protected access and the algorythm is still unknow
but the service reset shall be ok right ?
PaulMTS_V4S
as listed in the log file, I tried annual reset that did not work.
You expect service reset to work. Do you mean the button 'Service Interval' that is use for the oil change interval? Will this also reset 'annual service'?
service is oil
on certain bike it's not possible yet to reset the service date , some user deleted the lamp changing the date on the dash directly
PaulMTS_V4S
I tried 'annual reset' and 'service reset', none seems to work.
I changed the date to cancel the light.
Hopefully the service can be provided in the future.
gregtr
Post by gregtr »
I can confirm that annual service reset is still not working on my 2021 Multistrada V4S with 2.0.4.8 version of MelcoDiag.
I tried Annual Service 0, Annual Service 1, Change Service Date without any success.
Phil85
Post by Phil85 »
J'ai le même problème sur ma multistrada V2
J'ai réussi à enlever le voyant service pour la vidange mais pour le voyant contrôle annuel impossible.
Si vous avez une solution je suis preneur.
Merci pour votre aide.
seb_le_motard
Post by seb_le_motard »
Same issue on my MTS V4S 2022.
Impossible to reset annual service :(
