Installing sowtware M3C
Posted: Thu Jun 19, 2025 1:35 pm
by steenaage
Hi JP.
Thank you for the opetunity to use your software.
I want to reset the Desmo an oil service on my Ducati Multistrada 1200 S, 2013.
I have a problem installing the software after downloading and unzipping. I use Windows 11.
The M3C will not install. (and it's in French).
The Melcodiag new generation, seem to install fine...
...but I don't know which of them fits my bike.
Hope you can give me some hints.
Thanks.
Steen
Re: Installing sowtware M3C
Posted: Thu Jun 19, 2025 4:28 pm
mts1200 has a melco ecu , so melcodiag with anybike settings
Posted: Fri Jun 20, 2025 11:10 am
by steenaage
Ok thanks.
I tried Melcodiag, but I got the message : Data are incomplete.
I use the ELM 327 v.1.5. Is that ok ?
Steen
Posted: Fri Jun 20, 2025 5:08 pm
it's possible there is issues with elm v1.5
you can post your report then i will check it
Posted: Sat Jun 21, 2025 8:46 am
by steenaage
is it this one ?
https://jpdiag.akress.com/jpdiag.php?Lic=: : : : : 300_0400050000: 18_: 80_: 100_: Global_ vin
vin
vin
vin
vin
vin
vin
vin
vin
vin
vin
vin
11 PIDS active founds
080_0400050000
024_4C91A71A00000000
020_0A000048A4020000
018_00
022_00
100_C304183E803FE000
150_00
160_C8C86C6C6C6C0C00
210_00
190_4000024402001808
120_8026020202018108
: OIL0_DES0&UID=46F208F7
Posted: Sat Jun 21, 2025 8:50 am
no this is the registraion url ,
but i can see the elm is not compatible
each PID must be followed by 8 bytes , if you looks PID 150 , 018, 022, 210, there is missing 7 bytes
Posted: Sat Jun 21, 2025 9:41 am
by steenaage
I don't have much knowledge of how software works.
Would you say I should use an ELM v.1.4 instead of the v.1.5 ?
Posted: Sun Jun 22, 2025 10:25 am
yes
