Unlock ECU
folkone
Unlock ECU
Post by folkone »
Hello everyone,
I've looked into the faq section and forum but was unable to find any good information, hence this message.
I've like to understand how the "Unlock ecu" function works and whether the software has the capability to read the ecu map.
Any insight would be greatly appreciated!
Re: Unlock ECU
jpdiag cannot unlock the ecu ,
it can check the unlock / lock status ( immo function)
with the card code it unlock ecu untill next start
the reader is appart jpdiag .
it can be dowloaded too btw
folkone
Re: Unlock ECU
Post by folkone »
Understood: unlock ecu is a function related to the immobilizer.
How's about the map reader? What is it called and where can I download it from?
Thanks!
Re: Unlock ECU
