2021 ducati scrambler 1100 pro can not connect
suberacer
Post by suberacer »
i need to reset my service reminder and cant get anything to connect i have tired ELM327 V1.4 and V1.5 still nothing also have tried switching between HS-CAN, MS-CAN in all bikes mode checked and HS-CAN switch with ELM327 V1.5 it can only read the VIN number and failed to connect. says switch to scrambler setting. when i do it wont connect. i can not register melcodiag even though it says registered at the bottom. this is the data i get.
any help would be appreciated
thanks
chris
"File generated On 8/21/2025 12:08:19 AM"
"Software version 2.0.4.5"
"User Bike = 2021"
" vin:NO DATA>
174_FE7F006A0494031F
178_F47F03623C870311
17C_0A800100F9950398
080_1F02BC0305200C77
100_C81205BFFF001BDE
018_0002A00020C0488C
019_9609600000000926
300_4980000404064EB3
230_0000100000000E42
220_0000000000000EAC
024_0000000000000D8B
020_0040301000000FEB
188_7FF77C3F80634F0B
022_000000000003FF1A
023_00000054
"0C4C1C1C"
Re: 2021 ducati scrambler 1100 pro can not connect
as i read on internet , you shall put the switch on HS CAN.
don't forget to tick m3c before connect as well
suberacer
Post by suberacer »
yes i have tried that and it does nothing. if i dont tick the m3c if only reads the VIN number and says check the M3C button..
sorry for the late response..
