for all who are looking for elm.
Posted: Mon Aug 25, 2025 12:53 am
by Vlad
I read the whole forum and a lot of information on other threads, I still don't understand which elm I should buy on Amazon. I already bought one and it turned out to be non-working, if someone tells me which one I should buy, I'll be grateful. ducati multistrada 2014
Re: for all who are looking for elm.
Posted: Mon Aug 25, 2025 8:09 am
check odbauto , lonelec , bmdiag for the right cables
Posted: Mon Aug 25, 2025 2:11 pm
by kalex1711
I bought this one from Lonelec https://www.lonelec.com/product/obd2-wi ... ader-v1-5/
This works for me on three different bikes. There you can also buy the right cable.
In MelcoDiag you have to change the baudrate to 115200.
Regards Alex
Posted: Mon Aug 25, 2025 7:44 pm
by DESMAN
as kalex1711 told you, the right choice should be scan II BT ELM from Lonelec, I also tried lots of elm : 1.4 1.5 USB Serial , WIFi (I know melcodiag wifi is not supported), but the SCAN II work on all my bikes /(4 monsters ), so I think the best buy. I'm not saiyng others do not work , but ha ve to try too much (with drivers, com ports and baud rate) while with BT SCAN II you can work fast without config problems. 8-)
