MTS 1200 2014 Can't calibrate map or reset TPS
Posted: Sat Sep 20, 2025 6:28 pm
by raven_hammer
So, this thing is killing me. It ran a year ago, but due to travel and work, it sat for 8 months. Came back to run it, and it wouldn't run. Acted like a faulty fuel pump. New pump and fresh fuel, and still the exact same. Wont run, and when it does, it's barely running. Lays down like low fuel pressure. It had a P0105, so I replaced the MAP sensor, and still same result. I tried to select MAP Calibration, and it does nothing. Same with resetting the TPS. X-Scanner ELM with Windows 10. ELM327 v1.4
ECU Tag:
MTS1200
J00100020302
vs . MY13 USA
DUCATI085
