MYS 1200S DVT 2017 ISSUE
Posted: Fri Sep 26, 2025 8:59 am
by semtexale
Hi everyone.
trying to create the file for registering the software, I get an error. This is the log below. I think it doesn't read the ECU, could it be? It's a 2017 MTS 1200S DVT. Thanks for your help.
"File generated On 25/09/2025 19:30:56"
"User Bike = multistrada 1200s 2017"
"Softw = 10SW037916U"
" vin DATA
vin 135A905A444D414130304141484230313637323155
vin 7F1A1255555555
vin 7F1A1255555555
022_000000000003F4D5
023_000000FC7FCB0401
188_80138017806F441C
020_8000950000004A78
360_38E03325092500FF
018_0002A0008200667D
019_960960000000069D
300_3E980004267D8AFC
174_16800000626A0C52
024_00000B3E00203066
080_2BC0000020A0002C
100_C71202A027000072
178_4680052606800C0B
17C_00000000CA950C2
"Vin = ZDMAA00AAHB016721"
"D6F785B8"
ZDMAA00AAHB016721
Re: MYS 1200S DVT 2017 ISSUE
Posted: Fri Sep 26, 2025 7:33 pm
you don't need to create a file for registering .
if you press the get licence button , it shall open the registration webpage will all data alredy there , you only need to completewith your email and the bike model / year.
As ecu is empty in the 1st line of the prefilled data , it may fail , and if it fail , you can try to write in the first line no data
then it should by pass the check
Posted: Sun Sep 28, 2025 2:22 pm
by semtexale
I tried as you say but it gives me the same error.
I try to attach a photo of fields.
Posted: Mon Sep 29, 2025 3:52 pm
it looks ok
you can retry i made some changes
if it's still not working
the best is maybe to paste the registration link here , it's paste into the clipboard when you press blue button , i'll have a check with the same data as yours
Posted: Tue Sep 30, 2025 9:06 am
by semtexale
Thanks for the help. I did the procedure again and this time it went well, I received the license which I put in the same folder as the software. I restarted the application with the motorbike engine running. However, I noticed that my parameters detected are totally wrong (engine temperature, ambient temperature, engine rpm and even the total km are wrong). It also won't reset my annual service. How can I proceed? Thank you.
Posted: Sun Jan 25, 2026 8:43 am
by desmo32
Same Problem with my multistrada 1200 dvt.
Any ideas ?
Posted: Sun Jan 25, 2026 9:06 pm
lives values are not decoded for all bikes , if you have strange data , then you can go in the passive tab and monitor different PID to try to identify which pid is the right one and where the correct value is hidden .
i will try to record a video to explain it better
Oggetto: MYS 1200S DVT 2017 PROBLEMA
Posted: Sun Feb 15, 2026 10:21 am
by FrancescoG
Buongiorno, stesso problema, mts 1200 2017, licenza ricevuta ma non vedo nel campo ecu nessun dato, provando con il reset service niente da fare, il pc fa il suono dell’errore e non sparisce dal Dashboard
Posted: Fri Feb 20, 2026 5:12 pm
by Desmobiwan
Hello, same problem as Francesco. Successfully connected after received the license, but can't reset service light on dash board on my 1200DVT 2016. Just an "error ring" on my pc.
Posted: Tue Mar 10, 2026 8:31 pm
by ran-ran
Hi all,
I've had the same issue as many on here regarding reseting service items on my MTS 1200s (2015/16). From JP, on other threads, there are issues with resetting things (especially the annual service) with anything with the 10SW software on the bike, currently Melco can't do it unfortunately.
I found one way round this (change the date on the bike so it doesn't think its time to do the service) and one way to change it, use another paid solution to update the date for the annual service.
Hopefully JP will have enough data over time to figure out what's needed to successfully reset things in the 10SW bikes.
Hope it helps!
