				Melcodiag and license.
				Posted: Mon Feb 24, 2025 8:40 pm
				by luerira1
				Hello.
I am trying to read the DTC codes on my 2017 Ducati Panigale 959 motorcycle, but I have not been able to obtain the license to be able to perform this task, since the motorcycle has the check engine on and I have an overheating problem in the engine since the cooling fan is not working.
I have already connected the motorcycle to my computer and run Melcodiag, I also requested the license to be able to read the DTCs, but I have not received a response to my request.
I detected that Melcodiag does not read all the information from the ECU, I do not know why, and I also do not know if this is delaying too much for help with the license to be able to correct my fault and soon remove the 12,000 km service light, which is very close to reaching that mileage.
For some reason I received a license for a Ducati Hyperstrada 821 2014 motorcycle in my email, but I don't know if that license will be useful to read the ECU of my Panigale.
I'm sharing some images with you, I hope they are useful and hopefully someone can help me. There is no Ducati dealer in my city and I haven't been able to find a shop with the appropriate scanner to read the codes on my Panigale.
I also searched the Melcodiag ECU database, and there is no reference or anything similar to the model or ECU number that my motorcycle has installed. I don't know what to do, I need your help please.
				Re: Melcodiag and license.
				Posted: Mon Feb 24, 2025 8:45 pm
				by luerira1
				This is the label that is stuck to the ECU of my Panigale, I hope it is useful.
The image below is from an email I received, apparently it is a license, but I don't know if it can be used for my Panigale or if there was an error and they sent it to me when they should have sent it to someone else.
				Posted: Tue Feb 25, 2025 6:20 pm
				you can search with 959 instand of the software number .
also please post the debug report then i can check it
				Posted: Tue Feb 25, 2025 7:21 pm
				by luerira1
				jpl250rs wrote: Tue Feb 25, 2025 6:20 pm
Ok, very good.
I just have one question, how can I get the debug report?
				Posted: Tue Feb 25, 2025 9:59 pm
				press write report button , and find the MelcoDiag.exe.debug.txt file. paste its content here
				Posted: Fri Feb 28, 2025 2:13 pm
				by luerira1
				jpl250rs wrote: Tue Feb 25, 2025 9:59 pm
HOla, creo que este es el reporte:
"File generated On 17/02/2025 09:41:28 a. m."
"Auto Detect Bike = Panigale 959"
"User Bike = 2017"
" vin 145A8F035A444D3134423157364842303035363439
680_0842200000000000
018_00C8020000000004
080_00000808000000C8
020_00000000FFFF0000
024_0000000012800BFE
111_210147B440630CF0
"Vin = ZDM14B1W6HB005649"
"185C4B1B"
ZDM14B1W6HB005649
ZDM14B1W6HB005649
ZDM14B1W6HB005649
				Posted: Fri Feb 28, 2025 2:25 pm
				by luerira1
				luerira1 wrote: Fri Feb 28, 2025 2:13 pm
"User Bike = 2017"
"185C4B1B"
ZDM14B1W6HB005649
ZDM14B1W6HB005649
ZDM14B1W6HB005649
I just created this report a few minutes ago:
"File generated On 28/02/2025 08:23:03 a. m."
"User Bike = Panigale 959 2017"
"Softw = A"
6 PIDS active founds
024_0000000012800C00
"185C4B1B"
ZDM14B1W6HB005649
ZDM14B1W6HB005649
ZDM14B1W6HB005649
ZDM14B1W6HB005649
				Posted: Fri Feb 28, 2025 2:51 pm
				by luerira1
				luerira1 wrote: Fri Feb 28, 2025 2:25 pm
"User Bike = 2017"
"185C4B1B"
ZDM14B1W6HB005649
ZDM14B1W6HB005649
ZDM14B1W6HB005649
"Softw = A"
"185C4B1B"
ZDM14B1W6HB005649
ZDM14B1W6HB005649
ZDM14B1W6HB005649
ZDM14B1W6HB005649
				Posted: Sun Mar 02, 2025 1:33 pm
				ok you can see "lic not found
please put the cle.lic whitin the melcodiag directory , and the buttons will be enabled
				Posted: Sun Mar 02, 2025 8:38 pm
				by luerira1
				jpl250rs wrote: Sun Mar 02, 2025 1:33 pm
Hi bro. I put the file in, plugged the bike in, powered it up, ran Melcodiag, and it couldn't read any codes. This was the result.
I don't know what I'm doing wrong, but it doesn't read any fault codes, and the bike still doesn't have the cooling fan working.
I feel sad and desperate.
"File generated On 02/03/2025 02:29:24 p. m."
"User Bike = Panigale959 2017"
111_41014C8641330CB0
018_00C8160000000004
024_0000000012800BFF
240_A293D00000A89800
"185C4B1B"
ZDM14B1W6HB005649
