Getting message "If UMAP is loaded, please unload it before doing any resets"
Posted: Sat Oct 11, 2025 2:53 am
when I connect to my 2012 Diavel Carbon, I get the message "If UMAP is loaded, please unload it before doing any resets".
Is this a default message for everyone, or does it mean that the software has detected the potential presence of a User Map on my bike?
I bought this bike last year, and I don't know if it has a user map.
All I know is that it has a Termignoni exhaust which would require the "Performance ECU" to control the servo, but I've seen a receipt from the previous owner where the dealer mentioned that the performance ECU was not installed and this was causing a check engine light from the exhaust servo.
The dealer note reads:
Tech noted bike is missing a performance ECU from exhaust system. This is causing check engine light to come on for exhaust servo. Exhaust servo is removed with correct exhaust system on the bike. Ducati performance ECU would be required to correct check engine light.
PS: there's no further note to say that they added the performance ECU or flashed the stock one, but I don't have any check engine light so they have done something to fix it.
