fail after licence installed
Posted: Fri Oct 17, 2025 11:21 am
by dogfather33
Hi Im Bryan im trying to set a TPS on my ducati 848 2010 i can conect with freach install of Jpdaig drivers are good and ive got my licence Ive have pit in in program files Jpdaig x86 but after that it fails to conect am i doing something wrong plz help
Re: fail after licence installed
Posted: Fri Oct 17, 2025 6:35 pm
i see you asked 2 times for the licence , 1st time , serial was ok , second you posted a wrong serial.
which cle.lic are you using ?
Posted: Fri Oct 17, 2025 8:51 pm
by dogfather33
Ice tried both as soon as it connect I get readings and then it either give script errro I fixed that then when i connect as soon as I put licence it fails to connect. I've tried bike of just the one and usb plug it says connecting, but usually buy time I tune ignition one it comes up no response or just gets stuck trying to connect .
Posted: Mon Oct 20, 2025 10:51 am
by dogfather33
Can any help me with this I've referred bk to the first license I got still same think there is something wrong with either the laptop or the drivers but they are what I download I can't get to set TPS and the bike is running like a bucking bronco infact it nearly in ridable lucky it broke at end of summer I'm also going to change coil packed and plugs. Oh the bazaar remap is also saying the TPS is out of range .
Posted: Mon Oct 20, 2025 10:52 am
by dogfather33
I'll add some pictures if that helps
Posted: Mon Oct 20, 2025 4:42 pm
you can post the debug report and or pictures yes
Posted: Tue Oct 21, 2025 11:54 am
by dogfather33
Ok I've installed on a new computer now I'm getting run time error 340
