Melcodiag error message Pop Up "can't init ELM"
Posted: Thu Feb 27, 2025 5:33 pm
I am trying to connect Melcodiag to my ECU, but unfortunately I experience many show stoppers.
I spent many time to try to connect to ECU of my Ducati Hypermotard 950 SP Year 2019
I did also read carefully all the FAQ without being able to solve my problem even if I can confirm I tried many things following that FAQ.
I did also try with two different PC (one running Windows 7 et the other Win 11), problem is exactly the same.
When I try to connect I have the error message Pop Up "can't init ELM" even if I took care of the COM number, speed.
I did also reinstall FTDI drivers from the official site as mentioned.
I connect to motorbike ECU cable lead with 4 pins connectors and KKLcable from OBDAuto.fr website.
I am sure of that KKL cable as I can use it perfectly to connect to my KTM using TuneECU.
You can see my KKL which is that model in the link below
https://www.obdauto.fr/cable-kkl-specia ... 2x24744185
Where I cannot be sure is about my Ducati OBD cable 4 pins.
I mean I got it from AliExpress, but I don't know why it could not run correctly even is this is the first time I use it..
What can I do at that stage ?
I mean I am sure your Melcodiag works perfectly on a similar bike model same year (the one of a contact person I know), so ...
Shall I change both cables ?
or do you suggest me to check something else in my soft config ?
Thanks a lot in advance for the help.
