2nd OEM_MAP == UMAP? MTS 1260 Concerns UMAP reset OIL service
Posted: Mon Oct 27, 2025 10:10 pm
Hello together, Hello Forum,
I read two things that make me some concerns:
1. "!MELCODIAG! If you have UMAP installed, unload it temporarily before reset"
2. that someone destroyed his ECU by sevice reste while the bik had an UMAP installed.
How do I know if a "dangerous" UMAP is installed?
My Bike History for the ECU so far I know - ( little bit different than others).
MTS1260 2019, (MY 2018)
Default factory Map (!): 74 kW (due to limitations of the first owner)
After I bought it:
Official update of Ducati Dealer to ~116kW (default power of all common MTS)
Incl. Ducati confirmation datasheet incl. new Ducati CoC document
(Please see attachment)
Now: I wonder at melcodiag cause the ECU Info seems no clear characters - except the VIN, that is clear.
So my questions.
1. How do I know or detect if a "dangerous" UMAP is installed?
2. is this OEM_MAP of my dealer equal to an UMAP - cause after the factory the MAP was re-flashed once with the Ducati Map, the document says OEM_MAP?
3. Is there a potential risk to my bike by reseting the OIL service or some DTCs with melcodiag?
It would be great if someone can help me to answer these questions.
Read 1:
UUUU
UUU
95313053
300_30A8000A0B158D17
Global_ vin
145A8F035A444D4143303246414B4230303634373722
PIDS active founds
020_0000B90004008126
024_00000000000008E2
080_1A62BCC0502008A5
100_C712044041000845
022_000000000003F386
023_000000FC7FCB0352
188_800B7D1780434368
018_0002A000A4004A53
019_9609600000000B1C
174_0E800000986A066C
178_F87F0420027A0683
17C_00000000B994067F
130_0000050003E60100
110_00004310000C6C71
120_2865770D480027C0
200_0000000000000759
240_0200600442000802
150_0004007700004AC1
210_00000030FF00CA8C
300_30A8000A0B1584E2
230_121E1C00000CF4CE
360_48DE1827102500FF
ZDMAC02FAKB006477 OIL1_DES0
Read2:
UUUU: UUU: : 95313053: 300_30A8000A0B158963: 18_: 80_: 100_: Global_ vin
17 PIDS active founds
100_C71204404100038A
018_0002A000A40046CF
019_9609600000000780
020_0000B90004008768
174_168000009B6A00C5
178_0B800512027A00A8
17C_00000000DB940062
022_000000000003FC3D
023_000000FC7FCB0CE9
188_7FF77D1B80434C37
024_000000000000047E
080_1A62BCC050200439
220_000000000000000A
150_0004007800004635
210_00000034FF00E6D9
240_0200600442000402
110_00004310000C6499
: ZDMAC02FAKB006477 OIL1_DES0&UID=0CC51213
After I bought it:
So my questions.
Read 1:
UUUU
UUU
95313053
Global_ vin
PIDS active founds
Read2:
