my bike info does not populate in the software?
Posted: Tue Nov 04, 2025 3:09 am
by 2014mts1200bob
the obd2 adapter connects to com port 3, np. when the software is connected to my bike I hear sounds coming from the bike like its communicating. nothing populates in the field for bike info. any recommendations ?
Re: my bike info does not populate in the software?
Posted: Tue Nov 04, 2025 5:44 pm
you can post your debug report then i can start checking the possible causes
Posted: Wed Nov 05, 2025 1:56 am
by 2014mts1200bob
I forgot to include my bike is a 2014 Multistrada touring. I am looking to reset the oil change interval and the keyless code and continued maintenance going forward.
I copied and pasted the contents of the file. I hope this helps. thanks
`"File generated On 11/4/2025 8:43:17 PM"
"User Bike = 2014"
" vin:NO DATA
3 PIDS active founds
?_
"3271D8F1"
Posted: Wed Nov 05, 2025 9:36 pm
where did you buy the elm v1.5 ? i'm affraid it could be your issue
Posted: Thu Nov 06, 2025 1:28 am
by 2014mts1200bob
I bought it from ebay. I can try to return it. Is there an adapter you recommend?
Posted: Thu Nov 06, 2025 5:13 pm
lonelec,bmdiag,obdauto ...
Posted: Tue Nov 11, 2025 12:13 am
by 2014mts1200bob
so now I am connected but wont clear the oil reset it shows -500 every time I power on still. tried the pin reset- The pin start is no longer is an option when you press the power button with the key away from the bike. I would appreciate any help you can give.
"File generated On 11/10/2025 6:49:54 PM"
"User Bike = 2014"
"Ecu = MELCO HIMEJI "
"Hardw = J001"
"Softw = 00020302"
" vin 145A8F035A444D3132425357304542303130333030
6 PIDS active founds
022_0000000000000000
018_0000560000000004
020_07000048BE000000
080_04000500000000C8
024_6500F5B300000000
110_0032580440000E10
"Vin = ZDM12BSW0EB010300"
"3271D8F1"
ZDM12BSW0EB010300
Posted: Tue Nov 11, 2025 12:49 am
by 2014mts1200bob
I read the owners manual and the pin has been reset now. oops
Posted: Tue Nov 11, 2025 12:20 pm
how you wake it works so ?
Posted: Tue Nov 11, 2025 10:14 pm
by 2014mts1200bob
I tried connecting with the any bike option. The vin and software populates. when I go to the resets menu I click on the button for service interval or the reset dash pin, lights flash on my obd adapter but I don't hear the bike response. I connected with the M3C. M3D... option no info populated but when I click the button for service reset and reset pin I hear the bike responding. The pin did reset but the oil service counter did not reset.
