TPS Reset - 2019 Ducati Scrambler 800
Posted: Fri Dec 19, 2025 8:07 pm
by LBV
Hi
I have an issue after doing some work on my bikes airbox which required removing and reinstalling the box as well as the throttle body.
I forgot to disconnect the battery but now whenever I start the bike it revs VERY high.
I tried the TPS reset once. I wasn't sure if it worked (no message shown on laptop) so I did it again. Its till revs high after the 2nd one ( I never tried after the 1st).
Is it possible that the TPS reset work like a light switch in that I reset it the first time but then UNreset it again the 2nd time?
Much thanks.
Re: TPS Reset - 2019 Ducati Scrambler 800
Posted: Sun Dec 21, 2025 10:00 am
usually the reset record the actual throttle position as the reference throttle position.
it doesn't cancel anything
Posted: Mon Jan 05, 2026 7:02 pm
by LBV
Thanks but are we 100% sure that a TPS Reset even works on a 2019 Scrambler 800?
Posted: Mon Jan 05, 2026 8:37 pm
no , you will tell us if you have the opportunity to test it
Posted: Sat Jan 10, 2026 1:43 pm
by LBV
It did not work as the bike still revs very high after starting it.
What options do we have as i specifically got this to reset my tps?
I can't remember if i donated last summer when i got the software or not but happy to if it wirks.
Posted: Sun Jan 11, 2026 10:22 am
are you able to see TPS live values ?
idlle to full throttle ?
Posted: Tue Jan 13, 2026 7:36 pm
by LBV
I'll have to check the RPM on the screen next time I try starting it in the spring.
