2022 Desert Sled Euro 5
Posted: Sun Apr 05, 2026 2:22 pm
by cfcDave16
Hi would the software work for my Desert Sled 2022 Euro 5 - Annual Service Reset - thanks
Re: 2022 Desert Sled Euro 5
Posted: Sun Apr 05, 2026 8:35 pm
service reset yes , but annual i'mnot sure
viewtopic.php?t=45
Posted: Mon Apr 06, 2026 11:39 am
by cfcDave16
Hi thanks for the response - I bought 2 x ELM OBD 2 cables one has a switch and the other doesn't both are version v1.5
downloaded software from your site - attempted to connect firstly with ignition off but both have CAN BUS ERROR displayed
Then i turned ignition on and reconnected - no messages regarding CAN BUS ERROR but no other details are displayed
filled in details for bike and year and selected create report - report saved to main folder -
when i attempted to get licence an error came up on web page saying unable to send as some information is missing
Is there a user guide available - which gives step by step instructions
my com ports are set up correctly and the software connects but i cant seem to populate any bike info on the software
i have attempted all of the above with both OBD 2 Cables but the results are the same for both
any help or advice appreciated - have copied the debug text file below if it helps
"File generated On 06/04/2026 11:59:02"
"User Bike = scrambler desert sled 2022 euro 5"
" vin:NO DATA>
188_7FEB801F80CF4CE7
022_000000000003FC3D
18C_8003800200000DE4
023_000000547F130CC7
024_0000000000260E6C
150_00001092000042FA
020_0040001000000897
02A_0001800000000887
080_2BC2BC1F00200E7C
100_C802000FFF001D01
174_E67F0050466B04D1
178_0E800243816904E3
17C_048001007C81041A
"46EC8E36"
Posted: Mon Apr 06, 2026 1:24 pm
by cfcDave16
Hi have managed to reset annual service due -
tried different scenarios but was only able to get licence by selecting "any bike" to create report and forward to get licence
Once licence received - opened software and connected again by using "any bike "
Turned ignition on - connected - waited for ECU to sync and populate bike info - reset tab - annual service 0 and annual service 1 selected in turn and eventually cleared on display - took a couple of tries - thanks
Donated for you -
Posted: Mon Apr 06, 2026 8:14 pm
thanks ;)
so we can consider annual reset is working too , i'll add it to the success
Posted: Wed Jun 24, 2026 5:37 pm
by Desertghost
cfcDave16 wrote: Mon Apr 06, 2026 1:24 pm Hi have managed to reset annual service due -
Donated for you -
I have done in the same way but in the reset window all buttons are not working, only get service date is clicable.. but after i write in the date 260624 i can heard a double gong and a N/A in the window below
Posted: Wed Jun 24, 2026 10:29 pm
no button enabled means you havent unlock the registration
get date is for reading not to set date
Posted: Thu Jun 25, 2026 8:18 am
by Desertghost
jpl250rs wrote: Wed Jun 24, 2026 10:29 pm no button enabled means you havent unlock the registration
Ok, so what do i have to do to unlock the registration?
Posted: Thu Jun 25, 2026 5:50 pm
press the blue button get licence once you are connected to the bike
Posted: Sun Jun 28, 2026 7:20 am
by Desertghost
I’ve done it, it opens a white page that tells me i am already registered
