2024 Multistrada V4S license
Posted: Sun Apr 05, 2026 8:45 pm
by dolfanbolt
Can not get connected to get license. Cable is connected shows USB Serial Port com4 when connected, set in software as com4 but not connecting?
Re: 2024 Multistrada V4S license
Posted: Mon Apr 06, 2026 8:11 pm
what kind of interface are you using ?did you try different com speed ?
the report may help to diagnose the issue
Posted: Sat Apr 11, 2026 7:53 pm
by dolfanbolt
Lonelec KL-1 tried all the different com speeds. I have never used before, so totally in dark.
Posted: Sat Apr 11, 2026 10:44 pm
kl ?? it's fo jpdiag not for melcodiag
you need an elm based interface
Posted: Sun Apr 12, 2026 12:48 am
by dolfanbolt
Thanks, I will do that
Posted: Sat Apr 18, 2026 5:51 pm
by dolfanbolt
OK, i was able to connect and get licensed, now need help with procedure to activate the fog lights if you can assist.
Posted: Mon Apr 27, 2026 8:59 pm
by dolfanbolt
besides not being sure how to enable the fog lights or if It is doable, when I connected to running bike after licensing the bike cut off immediately, seems I am doing something wrong?
Posted: Tue Apr 28, 2026 7:31 pm
you shallnot operate on the bike engine running.
all activations are done ignition ON , engine OFF
Posted: Sat Jun 06, 2026 5:55 pm
by dolfanbolt
will I be able to enable the fog lights with this?
Posted: Sun Jun 07, 2026 8:29 pm
i've only functions for day light , im not sure it's what you are looking for
