Ducati Streetfighter V4 S 2021 diagnosis issue
Posted: Tue Mar 18, 2025 6:10 am
				Hello to all bike owners!
Basic information:
• Bike: Ducati Streetfighter V4 S 2021
• Software: MelcoDiag v.2.0.4.4
• License file: Accepted and exists in the path folder
• Adapter: OBD FTDI (Modified ELM327, v1.5 PIC18F25K80 + FTDI chip)
• OS: Windows 7 x64 + Driver for FTDI
I am experiencing some issues with the maintenance of my bike, a Ducati Streetfighter V4 S 2021, with the VIN code ZDM1F00AAMB002000, which I purchased from Japan https://motopodbor.com/1841431
1. First Problem:
When I connect to my bike using MelcoDiag, it says “Connect successful.” However, when I try to retrieve data such as “engine temp,” “RPM,” or “mileage” on the main page tab, it displays strange and incorrect data. For example:
2. Second Issue:
On the DTC tab, when I press the “scan for ECUs” button, it lists some ECUs. However, when I select any of them, the program says it cannot connect to or read the ECU.
3. Third Issue:
On the Resets tab, when I attempt to reset the dash pin because the previous owner from Japan did not provide me with the code , the program hides the image of the pin code and only shows the “reset dash pin” button. I have tried pressing it, but my bike does not react to this action, and I still cannot change or reset the dash pin.
Additionally, I have tried the Active Tests and Passive Tests tabs, but only the “keys” section shows some data. If I try to check indicators such as “brake switch” or “left indicator,” the program does not respond.
I do not understand why this is happening. Could it be because of the “No ECU data” mentioned in the letter with the license? I can share my experience with a video, screenshots, or a log file if needed.
I would greatly appreciate any advice on my situation, as:
Thank you in advance for your help!
			Basic information:
1. First Problem:
- The engine temperature shows -40°C,
- The RPM shows ~800 rpm,
2. Second Issue:
3. Third Issue:
- I cannot reset the dash pin (I have tried many variants, such as standard passwords like 1111, 0000, 1234, and even the last four digits of my VIN).
- I cannot switch my service interval to the next period.
