Panigale 959, ECU Connection /DTC Error
Posted: Wed Mar 19, 2025 10:23 pm
Hey,
I have a Ducati Panigale 959 (2017), and it seems like I cannot establish a proper connection to the ECU.
I can only connect using “38400” and “Any Bike”, which allows me to read the VIN and software version correctly.
However, under:
• ECU: Ð
• Hardware: 1Ð
These values seem incorrect—could this be a bug or an issue?
Issue with ECU Scan
When I navigate to the DTC tab and click “Scan for ECUs”, the following addresses are detected:
• ECU found on: 7DF, 7E9
• ECU found on: 7E0, 7E8
• ECU found on: 7E1, 7E9
• ECU found on: 7E3, 7EB
• ECU found on: 7E4, 7EC
However, when I select “ECU found on: 7DF, 7E9” and click “DTC on 7DF, 7E9”, I always receive the message:
“No answer on 7DF.”
This happens with all detected ECUs.
Issue when selecting M3C / M3D
When I select M3C / M3D instead of “Any Bike,” I can no longer read VIN, Hardware, ECU, or ECU Type.
Any idea what I might be doing wrong?
Context of the Issue
I previously disconnected my exhaust servo motor, which triggered a DTC error.
I then installed a HealTech Eliminator, but the DTC message is still present, and I would like to clear it.
I have already tried all baud rates, but the issue persists.
Report Data for “Any Bike”
Auto Detect Bike = Panigale 959"
"User Bike = Panigale959 /2017"
"Ecu = Ð"
"Hardw = 1Ð"
"Softw = 31D0"
vin 127FEBFF
vin 7F1A31FFFFFFFF
vin 31A8F1D7F1A31D0
vin 31A8F1D7F1A31D0
vin 7F1A31D0
vin 7F1A31D0
vin 1A5A8FD05A444D484130304141484230303434343432
080_00000708000000C8
018_00C81200000004
120_7406010040FFC022
022_000000000010000
200_0000008080
024_0000000012800C00
680_0742000000000000
020_0000000FFFF0000
018_00C81A000000004
022_000000000010000
240_8293D00000A89600
024_000000127FEBFF
111_C10145AE40400CE0
"Vin = ZDMHA00AAHB0044xx"
"FA079296"
"lic found"
"ZDMHA00AAHB0044xx"
Report Data for “M3C / M3D”
File generated On 19.03.2025 22:23:28
Software version 2.0.4.4
ELM version : ELM327 v1.5
User Bike = Panigale 959 / 2027
CAN Bike =
Ecu =
Hardw =
Softw =
OilService = NO
DesmoService = NO
Vin = NO DATA
5 PIDS active founds
018_00C81E000000004
022_000000000010000
020_0000000FFFF0000
DTC =
FA079296
Bike = 4
lic found
registered
Do you have any advice on what else I could try?
Thanks in advance!
"Auto Detect Bike = Panigale 959"
"Ecu = Ð"
"Hardw = 1Ð"
"Softw = 31D0"
vin 127FEBFF
vin 7F1A31FFFFFFFF
vin 31A8F1D7F1A31D0
vin 31A8F1D7F1A31D0
vin 7F1A31D0
vin 7F1A31D0
018_00C81200000004
022_000000000010000
200_0000008080
020_0000000FFFF0000
018_00C81A000000004
022_000000000010000
024_000000127FEBFF
"FA079296"
"lic found"
"ZDMHA00AAHB0044xx"
However, under:
• ECU: Ð
• Hardware: 1Ð
Issue with ECU Scan
“No answer on 7DF.”
"Ecu = Ð"
"Hardw = 1Ð"
"Softw = 31D0"
vin 127FEBFF
vin 7F1A31FFFFFFFF
vin 31A8F1D7F1A31D0
vin 31A8F1D7F1A31D0
vin 7F1A31D0
vin 7F1A31D0
018_00C81200000004
022_000000000010000
200_0000008080
020_0000000FFFF0000
018_00C81A000000004
022_000000000010000
024_000000127FEBFF
"FA079296"
"lic found"
"ZDMHA00AAHB0044xx"
CAN Bike =
Ecu =
Hardw =
Softw =
OilService = NO
DesmoService = NO
Vin = NO DATA
018_00C81E000000004
022_000000000010000
020_0000000FFFF0000
DTC =
FA079296
Bike = 4
lic found
registered
Thanks in advance!
"Ecu = Ð"
"Hardw = 1Ð"
"Softw = 31D0"
vin 127FEBFF
vin 7F1A31FFFFFFFF
vin 31A8F1D7F1A31D0
vin 31A8F1D7F1A31D0
vin 7F1A31D0
vin 7F1A31D0
018_00C81200000004
022_000000000010000
200_0000008080
020_0000000FFFF0000
018_00C81A000000004
022_000000000010000
024_000000127FEBFF
"FA079296"
"lic found"
"ZDMHA00AAHB0044xx"
