EVO 1100 Not communicating properly
Evo1100
Post by Evo1100 »
Downloaded latest verstion of Melcodiag
I/F is ELM 327 v 1.5 as detected by MD
Comm driver installed without issue
Speed is 38400
ECU set to M3C
Could not request license due to Missing Data
Selector switch on I/F set to SH
Key Switch is on, Not Engine
Debug Output:
"File generated On 7/11/2026 5:48:41 PM"
"Software version 2.0.5.1"
"User Bike = 1100 EVO / 2012"
"Hardw = CAN ERROR"
"Softw = CAN ERROR"
6 PIDS active founds
080_0000000000000000
081_01000000C8000000
010_C800000000000000
018_00E1000000000000
020_0000060000000000
100_E000000000000001
"Vin = CAN ERROR"
"4EB59B1D"
PaniVIN:
MultiVIN:
M3dVin:
DashVin2:
DashVin:
EcuVin:
Assistance Requred.
Re: EVO 1100 Not communicating properly
the CAN ERROR message is not good at all .
Have you tried the other switch position ?
Evo1100
Post by Evo1100 »
Yes, the other position, and also oher speeds. Everything but the current setting resilts in popups complaining that communications is not working.
In this setting at least I get a lot of blinking green and yellow lights.
If i switch to the "all bikes" setting I also get a lot of blinking lights, but still, lots of missing data.
what data are you getting ?
an other report with this setting will help
Evo1100
Post by Evo1100 »
Here is the data with the "Any Bike" ECU setting.
"File generated On 7/12/2026 11:30:23 AM"
"User Bike = 1100 EVO 2012"
"Hardw = N/A"
"Softw = N/A"
018_00B1000000000000
211_42880042D000005B
"4EB59B1D"
PaniVIN:
MultiVIN:
M3dVin:
DashVin2:
DashVin:
EcuVin:
Evo1100
Post by Evo1100 »
Good News1.
I got it to work.
I have a Monster 696 as well.
I tried using that and got pretty much exactly the same resuits.....even when I tried with the Key OFF.
I did not believe that to be right.
Tried other USB ports, and finally found one that would work.
I have submitted for both licenses.
The EVO reports "Vin = 0060457571 "
The 696 reports "Vin = 0060229322 "
