2015 Multistrada 1200s TPS reset
Obligate6495
Post by Obligate6495 »
Hello, I got my license added into the Melcodiag directory and I was able to connect to my bike. The software seems as though it's able to read everything though it is slow to update on my computer. I recently replaced a throttle body on my bike and am in need of this software to reset the TPS. If i start the bike now it immediately redlines so i need to reset the TPS before starting. Needless to say I have done all of my testing with the bike's power set to accessory and ignition off. My bike also needs the "Date service" light reset. I assume this is simply the oil service reset. each time I click one of the reset buttons it doesn't seem to have any effect and the service light is still on on the dash. I've tried power cycling the dash to see if it goes away but no luck.
If someone is able to help me with this I would greatly appreciate it. I would much, much rather make a donation to this software rather than have to pay a dealership to reset the TPS/service light :D.
"File generated On 7/15/2026 16:47:36"
"Software version 2.0.5.1"
"Auto Detect Bike = MTS1200"
"User Bike = 2015"
"Hardw = N/A"
"Softw = 10SW037951"
022_000000000003F5C8
023_000000FC7FC7056B
188_800B800F804345A4
174_468000009D6A0952
178_1F800332257F097D
020_0000910000004F05
17C_00000000DD9509DE
110_6109580440000E10
018_0002A000800041AA
019_96096000000002E9
024_5A00000000400D6E
080_19A4000010200D5D
100_C712191191000DFE
*ECU found TX:7E0 RX:7E8
*ECU found TX:7E1 RX:7E9
*ECU found TX:7E6 RX:7EE
"Vin = ZDM12BWW3FB002509"
"7C734242"
? outp='ZDM12BWW3FB002509'
PaniVIN: ZDM12BWW3FB002509
NO DATA
0120
NO DATA
037F101200000000
0250011200000000
065A920026071500
Re: 2015 Multistrada 1200s TPS reset
service date looks annual service reset
since 260715 yesterday i guess this indicator switched on
2 things :
the 10sw software is very difficult to reset.
some people succeed resetting the annual service by changing the date on the dashboard
for the tps reset i haven't add it yet for your bike .
we'd need to test the different solutions to check which one is ok
we can do it together by remoting your pc with rustdesk
Obligate6495
Thanks so much for the reply. I'd be happy to help out with rustdesk and work through it together. Just let me know how I can help and when you're available
have you tried the button tps reset open and tps reset closed ?
Obligate6495
Hey JP, I've tried both of the TPS reset options shown here as well as a number of the other service resets here and the bike didn't react to any of them. The service light is still on the bike after a power cycle and i didn't hear any relays clicking or noises from the bike. laptop did buzz with a few of the service resets but not the TPS resets. Also the tx/rx lights on my ELM would light up when issuing the resets so that is promising. I also tried the APS reset option with no effect.
Obligate6495
Is there something else that I can do to help or troubleshoot?
is your tps is controlled by cables or by electronics ?
Obligate6495
Electronic. Not cable
Obligate6495
If you're available I can use rustdesk today to troubleshoot
ok send me your id/pass
