2019 Scrambler 1100 ECU N/A
Posted: Sat Jul 18, 2026 2:58 pm
by Mydamnwell
Hello! I am trying to get my Ducati Scrambler 1100 linked to MelcoDiag and running into an issue with the ECU. When attempting to connect via 'any bike' it will read the vin but prompt me to use the m3c setting. When I do that I get no vin and ecu reads n/a. It does still connect and it will discover the four modules for DTC's (it will read/clear 3 of the 4). I was told this bike has been 'flashed' with an upmap for the Akrapovic exhaust that is on it. It also has a dynojet power commander plugged in. This was all done by the previous owner and I personally hate this stuff. It should remain as the factory built it but that is tangential... I don't know if I need to unplug the dynojet or if the ecu upmap is causing the error. Any advice? The 'get license' box disappears as soon as it connects but I did manage to get a license file with the n/a ecu. I will attach the debug info in the next message.
Re: 2019 Scrambler 1100 ECU N/A
Posted: Sat Jul 18, 2026 3:01 pm
by Mydamnwell
"File generated On 7/18/2026 10:35:01 AM"
"Software version 2.0.5.1"
"ELM version : ELM327 v1.4b"
"Auto Detect Bike = Scrambler 1100"
"User Bike = 2019 scrambler 1100"
16 PIDS active founds
188_80137FAF80BF4923
022_000000000003F954
023_000000547F5B091E
020_004020000000096E
018_0002A00038C0CA84
019_9609600000000B1C
178_19800000438100F5
17C_0000000092970055
100_C8121080000001F9
024_0000000000200245
080_1F73B70305200232
240_0000012C000F4521
120_02007C3E940006C8
200_0000000000000644
150_0003107C000246C2
210_000000410000465E
"Vin = ML0KAFCP9KT000422"
"DTC = 0258000000000000 0258000000000000 10085802061B4004 0258000000000000 0258000000000000 0258000000000000 0258005555555555 0258000000000000 0258000000000000"
"1C3A5D13"
"Bike = 5"
065A920024011400
065A920024011400
065A920024011400
? outp='ML0KAFCP9KT000422'
PaniVIN: ML0KAFCP9KT000422
Posted: Sat Jul 18, 2026 3:42 pm
i send you a beta version , please test it and post report
thanks
Posted: Sat Jul 18, 2026 5:16 pm
by Mydamnwell
Hi thanks for sending that over. Unfortunately still the same problem. I disconnected the DynoJet Power Commander to isolate any issues and it made no difference. It is a continential ECU so it should be readable. I am using the same software and hardware on my 2021 Scrambler Desert Sled, it works on that bike. Also I guess I cannot obtain any additional license files as the data reads 'bike=5'? It is admittedly my fourth Ducati I have connected to MelcoDiag but maybe I accidentally made a 2nd license for the same bike? Anyway it is not a huge deal for this Scrambler 1100 I only want to reset the annual maintenance, I just rolled the date back on the display for now.
Posted: Sun Jul 19, 2026 9:35 am
so you confirm it's a m3c ecu ?
please send the report with the new version , i changed bike to 9 to try if it's same electronic than EU5 bikes
Posted: Sun Jul 19, 2026 1:41 pm
by Mydamnwell
It is a Continential ECU and 99% sure it is m3c, the software prompts me to reconnect using that method regardless. Here's the two debug files. First one is using m3c. Second set is after choosing 'ANY BIKE'. I still cannot click the 'get license file' after connecting, it disappears after the green bar gets full.
First debug report: M3C
"File generated On 7/19/2026 9:25:47 AM"
"Software version 2.0.5.2"
"User Bike = 2019 scrambler 1100 special"
" vin:NO DATA>
19 PIDS active founds
100_C812104000000DC4
020_0040201000000399
022_000000000003F0A1
023_000000547F6B002A
178_0380090F5C81079C
17C_0000000047970737
188_7FF77F9B809F40AA
024_0000000000200ED9
080_1F71F70305200EBD
210_0444004D00800DA5
018_0002A00038C0C26C
019_96096000000002E9
240_0000012C000F4CD4
120_02007A3E94000A35
200_0000000000000AD8
230_0080100000000CD8
220_0000000000000C96
150_0003107A00024E43
174_1F8000000B940F24
"1C3A5D13"
Second debug report: ANY BIKE
"File generated On 7/19/2026 9:26:30 AM"
"Hardw = A2C9295020099"
"Softw = QD1E0010"
17C_000000004F970DE9
020_004020100000094B
080_1F71F70305200221
150_0003107A00024910
018_0002A00038C0C8BE
019_960960000000083B
100_C81210400000027F
188_80077FA380B34731
022_000000000003F7F2
023_000000547F6F0754
178_0080022056810E6A
240_0000012C000F48A0
120_02007A3E940006A9
210_044400300080C950
230_00801000000008AC
220_00000000000008E2
360_4819081501240000
"1C3A5D13"
"Bike = 9"
? outp='A2C9295020099'
