Page 1 of 3
Unable to reset Desmo Service on 2015 Scrambler
Posted: Sat Aug 08, 2026 2:34 pm
by derek996
I'm running the most recent version of Melcodiag and trying to reset the Desmo service on my 2015 Scrambler Classic. I have a licence and Melco reads the ECU and registers the licence. When I click on Desmo Reset the blue bar illuminates the lower half of the button them goes out with a beep sound. But when I check on the dash the service light hasn't cleared. This is the debug file:
"File generated On 08/08/2026 14:53:13"
"Software version 2.0.5.2"
"User Bike = Scrambler 2015"
"Ecu = 5WY8691-AA"
"Hardw = QD0G1010"
"Softw = 1CABAAG1"
" vin:100E5A8C3430303021313130303331202220AAAAAAAAAAAA
081_00000000C8000000
020_52B8C00000000000
022_0000000000000230
100_00000A0000000001
300_2D7100005EE5000B
029_0000000000080000
240_255AC00000289D00
201_0000000
"Vin = 4000110031 "
"1AB4FDC8"
000110031hard :QD0G1010
scrambler detected
soft :1CABAAG1
Re: Unable to reset Desmo Service on 2015 Scrambler
Posted: Sat Aug 08, 2026 9:42 pm
all dll files present in melcodiag directory and unlocked ?
Posted: Sun Aug 09, 2026 9:51 am
by derek996
Both .dll files are present in the same directory as the melcodiag.exe and the cle.lic and are unlocked. I have installed another download but haven't tried it yet.
Posted: Mon Aug 10, 2026 2:05 pm
by derek996
I've installed a new download and reloaded the FTDI drivers. The result is exactly the same, licence is recognised but I'm unable to do any resets or static tests. When reading DTCs it got stuck in a loop and I had to quit with Task Manager.
I have 3 ELM327 units, the most recent from Lonelec which used to work perfectly but now it comes up with "Can't init ELM, check your COM settings".
It does connect with another ELM which uses the wnc. driver.
When I tried connect to any bike i got an error saying "ERR Checkbox2: A device attached to the system is not functioning.
If it is of any consequence I used to a Laptop with Windows 95 and it worked fine. I now have on running Windows Vista. Could this be an issue?
Posted: Mon Aug 10, 2026 9:58 pm
win 95 is very old i'mnot it can work if you don't instal visual redistribuables
same for vista.
you don't have newer OS ?
Posted: Tue Aug 11, 2026 10:36 am
by derek996
No I don't have a newer OS. The Laptop I'm using won't support Windows 10 or 11. I'm a Mac user and don't want to spent a lot of cash on a Windows laptop that will get hardly any use.
I should add that my current setup worked perfectly well to reset the oil service light on my Supersport 939 about 3 weeks ago, so the issue would seem to be software related and not the hardware.
Back in 2022 when you were looking into adding the Scramblers to Melcodiag you sent me an .exe to try and return the debug file to you which I did. You then sent me another .exe which reset the service light. I sent you the debug file and I believe this info was used for Melcodiag 2.0.1.5 which incorporated the Scrambler. This was using my previous Windows 95 laptop and the same ELM cables that I currently have. I have tried the same .exe and I'm mystified as to why it doesn't work now.
Posted: Tue Aug 11, 2026 6:34 pm
current version is 2.0.5.2
2.0.1.5 seems very old to me i'mnot sure it was working with scrambler yet
you have to tick m3c before connencting then it shall be ok
Posted: Tue Aug 11, 2026 6:55 pm
by derek996
I'm currently running 2.0.5.2, 2.0.1.5 was the test version you sent me. back in 2022. And yes I tick the M3C box.
Posted: Tue Aug 11, 2026 8:41 pm
don't forget to unlock the dll files
Posted: Wed Aug 12, 2026 11:53 am
by derek996
How do I unlock the .dll files? Why would the installer install locked files?
